I'm looking to pick up a 65" Panasonic VT50. I have a Samsung 61" DLP that's about 6 years old and about to need it's second bulb and starting to have glare in the upper left corner from some slight sagging. So now seemed like the time to buy. I just had a few questions...
1) This will be my living room TV so often has a lot of light coming in from the left side. This shouldn't be a problem right? It has to be brighter than a DLP.
2) I play PS3 about 5% of the overall use of this TV. All the plasma "issues" from 5+ years ago are gone at this point? Mainly speaking to image retention and latency.
3) Do most people mount these or place them on a stand, they seem incredibly heavy. I have a glass topped Bell'O stand I was wondering if it would break, and if a mount is necessary are the mono price low-profile ones that hold like 165lbs fine? Also do you usually mount them higher than a DLP would sit and tilt down slightly or mount them just a couple inches over the stand?
4) Based on past history the price seems to be pretty stable for the first 4-6 months after release then drop pretty steadily from there? Is there any reason to anticipate a noticeable price drop over the next 3 months or so? I can't wait much longer than that or I'd have to invest in a new bulb on the old DLP.
Thanks for your help if everything looks good I'd like to purchase today!!
