AVS › AVS Forum › HDTV › HDTV Technical › I'm looking for a good 15 foot HDMI cable for my Xbox 360
post #1 of 5
But I don't want to spend too much if I can help it.
Are any of these good?
http://www.ebay.com/itm/15-Feet-15Ft...item20c06abda4
http://www.ebay.com/itm/15-ft-High-S...item256f6b8cea
http://www.ebay.com/itm/15-FEET-HDMI...item2c63014a61
http://www.ebay.com/itm/2X-15-ft-Hig...item256f859ef7
post #2 of 5
Don't use ebay, just get it from monoprice.com and be done with it.
post #3 of 5
Monoprice...
post #4 of 5
There is no length specified in the spec but for Cat 1 HDMI cables try to limit to 15ft or less and for Cat 2 HDMI cables try to limit to 50ft or less.
For more information this is a good resource: http://en.wikipedia.org/wiki/HDMI
post #5 of 5
A certified high speed cable is all you need. The problem is finding one that is really certified. Trying to do it on eBay is hopeless unless you are buying a known brand (and it isn't counterfeit). Buy from a reliable source, like monoprice, Blue Jeans Cable, or AV Science, and you will be safe. They all have 15' certified high speed HDMI cables that will handle any signal currently supported by the HDMI specification.
  Back to Forum: HDTV Technical
