Hi all,
I just installed an antenna for OTA reception on an old Dish Network mast from a previous tenant. The mast is attached to a steel clothesline pole, and didn't seem to have any additional grounding.
Is the steel clothesline pole enough of a ground itself that I shouldn't worry? Does the coax cable leading into the house need to be grounded as well?
Thanks for the help...
