Abis lxled 2
post #1 of 4
What do you think about this projector?
ABIS LXLED 2
http://www.projectorsite.co.uk/index...=133&parent=26
Thanks for posting your opinions here!
post #2 of 4
http://www.youtube.com/watch?v=vspwGITHYi8
Technical Specifications:
Resolution: 1280 x 800 native, Full HD 1080p compatible
Brightness: 2,600 Lumens
Contrast Ratio: 3500:1
Aspect Ratio: 4:3 or 16:9 (note: older version projectors do not have 16:9)
Picture Size: 30" - 450"
Zooming: Digital and Manual
Fan Noise: Standard (average 20db to 30db)
specs look good but for the price I would rather have a Optoma ml500 or a ViewSonic PLED-W500
post #3 of 4
You would buy ML500 instead of this with 2600 lumens? I am not sure if I can trust these specification, what do you think?
post #4 of 4
If you really think this thing outputs 2600 lumens you will be in for a big suprise. These are the LED specs for output not the actual light output from the projector lens. CRE does this... they list the specs of components and not the projector.
