AVS › AVS Forum › Display Devices › Display Calibration › Panasonic VT50 Self Vs. Pro Calibration
Panasonic VT50 Self Vs. Pro Calibration - Page 7
post #181 of 199
Originally Posted by sillysally View Post
Yes I saw your post and charts. That's why I ran autocal with the new calman4 b395 software.
The only differences are, I used normal, 2.4 and a i1pro meter.
Now if you read what was fixed with this software, it had nothing to do with autocal. However it does have a fix for the i1pro 2, and because I have one on its way to me I downloaded b395.
btw if anybody is interested in the i1pro 2 basic, amazon just dropped there price on this to $964.
ss
2.4 did not work for me ever. What is so terrible about your autocal screen shot? The dE looks lower than 3 to me. I tried targets 0, 0.4, and 0.5. All got the dE really low. What are you using?
post #182 of 199
SS
What was the fix for the i1pro2???????
Have you had a chance to take a look at 3d calibration?? Thoughts??
post #183 of 199
Originally Posted by JimP View Post
SS
Actually, not only for the i1pro 2 but for the I1display (D3). I guess the fix is for better comparability with Calman.
Don't know if it works or not, I will be trying out my i1pro 2 with the b395 software tomorrow night.
No I haven't done anything with 3D yet, Jeff (UMR) is going to be stopping by my house next month to help me out with 3D. But mainly for the light reading with his Photo Research PR-670.
Getting the dE low is not a problem, the problem is not using green to get there. Plus the fact that autocal does not calibrate are CMS, nor set the light level (contrast).
Yes using the settings I did is a bit unfair, however I can get good (not great) results when I do my calibrations manually with those settings. As far as the dE targets go I used the default, what ever that is. I normally use a setting of 0.
That said, your charts look good but without seeing the numbers I really can not say for sure if your calibration is good or not so good.
Anyway you are off to a good start.
ss
post #184 of 199
ss
You can autocal the CMS. I spoke with someone at Spectracal in April or May, and they told me that they removed or hid the Autocal for CMS because it did not work as well as they wanted it to. They also said they were working on it and would add it in later in the year. I know how to add it back in. I have used it in the past and it did not yield good results because of the inoperable luminance controls at the time. Autocal CMS works really good now. You have to add your own action button and set the command to do DisplayAction.SetAllGamut. See the screenshot below.
Edited by alston80 - 8/7/12 at 4:25am
post #185 of 199
Originally Posted by turbe View Post
f/w update v1.150 may be reducing luminance at 100% white a bit using PB Medium, so those with existing professional calibrations should not update now IMO, additional data/confirmations will be/is coming in.
Also, this new f/w update is for North American Regions Only, I've gotten a few emais from my Euro/UK Users asking about it for their models - this f/w update doesn't exist/is not for Euro/UK models.
Turbe,
Anything new to report on this? Is SpectraCal satisfied that all issues have been resolved with the new release or is SpectraCal still working with Panasonic on this?
TWD
post #186 of 199
Yes, I updated my post above the one you quoted..
Not exactly as I originally posted (though there was one report for that), but from Calibrator reports including from Kevin Miller who has already posted, it's best to not update unless you can get a recal.
8/4/2012 Update: For those who have had their displays professionally calibrated already, it is recommended that you do not update to v1.150 and you contact your Calibrator.
Originally Posted by Monitorman View Post
Hi all,
I just did 3 VT50s yesterday. I did a Software Update to 1.150 I believe on all 3 panels. This enabled the Luminance controls in the CMS. It also changed the luminance of the colors and made it critical to adjust the luminance of all 6 colors to get it correct. This means it most definitely alters an already calibrated VT50. My advice would be to not do the update if you have had your VT50 professionally calibrated.
Also on these models, there is size and unit to unit variation including with common builds in regards to performance with the update..
The Calibrators who have already provided feedback to me for post v1.150 indicate that this is a recommended f/w update
The bottom line, you will want this update so schedule a recal... it is also being pushed down the pipeline by Panasonic.
Edited by turbe - 8/7/12 at 8:56am
post #187 of 199
Thanks for the tip.
I think you can also use Standard Interactive mode to access both Gamut and Grayscale, and let autocal do the work. Simply drag and drop what ever you are working on.
ss
post #188 of 199
Thanks for the tip.
ss
I tried the interactive stuff before. IMO doing the autocal works better and it will save you time. Especially when doing the grayscale.
post #189 of 199
are these VT50s that hard to calibrate manually that spending hundreds on auto-cal is worthwhile? just curious
post #190 of 199
With the new firmware I was able to get a good calibration (using ControlCal) in about 3 hours.
post #191 of 199
that's not too bad, especially given all the picture controls this set has
post #192 of 199
I think most of us get a kick playing with our toys. An automated calibration kinda fits that profile. If you notice, most these guys also do the manual stuff too.
post #193 of 199
I just noticed something weird with the IRE Gain controls in the Gamma Detail Adjustment menu. I am using Calman 4 and when I change the gain for ISF DAY it also changes for ISF NIGHT. So both my night and day settings will have the same gain value. Can anyone who uses Calman 4 test this? All the other IRE controls are specific to their ISF mode except the Gain. This is the same as the IRE luminance if you are using the DDC workflow.
post #194 of 199
I got around this by using ControlCal. Thanks Turbe!
post #195 of 199
Hi,
I don't know whether this is the right thread but I'll try anyway, because the most knowledgable ppl seem to lurk here...
I'm looking into getting the European VT50 for domestic as well as studio use as a preview/grading monitor...I'm more or less aware that I can expect fairly accurate rec709 picture from the THX mode...(APL issues aside for accurate black level monitoring, still undecided whether it's a deal breaker)
however, I learned that this TV has the possibilty of a wider gamut operation, i.e. the wide gamut option (color remaster in the european version) unlocks the gamut simulation i.e. the TV is allowed to use the full gamut of its phosphors...
does anyone know what colorspace is it closest to i.e. which wide colorspaces fall inside it: P3, AdobeRGB, xvYCC...? I was hoping to perhaps use it to grade the shorts I produce on it, for P3 digital cinema projection (would require to be shot in wider colorspace, of course, say xvYCC or professional cameras like RED)...I also rely on the "pure direct" mode to get 4:4:4 chroma resolution, will it work in wide gamut mode? also will the VT50 accept and work with true 10-bit input from the graphics card?
Thanks...
post #196 of 199
Originally Posted by mytbyte View Post
Hi,
I'm more or less aware that I can expect fairly accurate rec709 picture from the THX mode......
Just from production variances, it won't be that accurate.
For your application, you'll need to be sure that it's frequently recalibrated.
post #197 of 199
Thank you...
the idea was not to have absolutely accurate display but one that I can trust is close to reference from the factory without the of need for calibration (I don't have a client to rub my nose in it )biggrin.gif...
however I confirmed myself that ABL and 50 Hz bug are present and am slowly steering away from VT50, albeit not completely yet...
post #198 of 199
As a Silver Premier customer at Best buy I am entitled to free calibration through geek squad.
Please comment.
post #199 of 199
Please comment.
This was asked last week, here is what everyone said
http://www.avsforum.com/t/1455980/best-buy-calibration-yes-or-no-free-service-from-rewards/0_100
