AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ
The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 48
post #1411 of 7823
Originally Posted by BFJ 96 View Post
I picked-up an Open-Box 2113CI with No Remote & No Manual. I programmed my Harmony-1 to the Denon but for some reason I cannot get the Denon Interface to move up & down when in Source Input. Is there any advance programming on the Harmony-1 I am missing? I'm also having a hand-shake issue with my Panny BD-65. Any help would be appreciated.
Thanks community
I'm coming from an Onkyo 605 where I could access the GUI from the front of the receiver. Is this possible with the Denon?
Denon removed GUI access from the front panel on all models but the 3313CI. Did you load the 2113CI remote to the ONE? If yes, you may want to try either reloading the codes again or try using another model (eg. 3313 or 3312).
For the BDP issue ---> http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100#user_L18
post #1412 of 7823
Originally Posted by freakjim View Post
Just got the first firmware update notice on my 2113, any info on what it's for?
Denon confirmed a new update was issued on August 9 for both the 2113CI and the 1913CI. Refer to post #6 for the firmare change log information.
I also checked on the Spotify firmware upgrade, although there is no new news as to when to expect it.
Edited by jdsmoothie - 8/10/12 at 7:23pm
post #1413 of 7823
Tried most of the troubleshooting tips & no luck. Also still can't get the right codes into the Harmony-1. What's frustrating me the most is not being able to move the On-Screen GUI when pressing Source Select up & down so I can change the resolution from AUTO to 1080p. Figures it would be too good to be true. Back she goes to BB tomorrow.
Thanks for the help
post #1414 of 7823
If you can't get the "right codes" into the ONE, what codes are you getting? Have you tried using other model remote codes as I suggested? Otherwise, you might want to check with Denon to see if they will ship you the proper remote free of charge.
post #1415 of 7823
2. 8/9/2012
----The unit shows no picture and sound via HDMI, and the Firmware version of GUI becomes FFFFFFFF.
Hurray! This is exactly what I'm also seeing from my 3313ci! I'm crossing my fingers that we'll see a 3313ci firmware upgrade soon!
post #1416 of 7823
Originally Posted by sheshechic View Post
I received my new speakers and the S10.3, so I hooked up the 2313. I went through setup and there were only 6 measurements taken.
This was an intentional change made by Denon to reduce the amount of time to run AUTO SETUP (based on some owners complaining the process was taking too long) and although may have minimal effect on the integrity of the Audyssey filtering process, for the most accurate results it's recommended you bypass the Setup Wizard using the Speakers - Audyssey Setup method to get all 8 mic positions.
Edited by jdsmoothie - 8/11/12 at 7:50pm
post #1417 of 7823
I have a harmony 880 and it can control the 2113 without any problem. I loaded "Denon avr-2113ci" code to my harmony, please try that.
Also, what do you mean 'move the On-Screen GUI when pressing Source Select up & down'? Are you in the setup menu?
You can also http to your Denon from the web browser to change pretty much anything. I have no need for the denon remote for a long time.
post #1418 of 7823
Hi All,
I just received a refurbished AVR-1913 from B&H Photo for $357.15 (includes tax+shipping). When I first hooked up the unit I got nada. No sound, no video, nothing. It took a couple days reading through this thread, FAQs, and troubleshooting posts but now I have video working and audio working but ONLY from iTunes Airplay. So far, what I had to do was connect to the receiver via IP address. It took several tries but I finally got the firmware updated.
So right now my issue is that I cannot get video-based sound. I have three video input devices (all hooked up via HDMI): a cable TV box, a blu-ray/DVD player, and an Apple TV. I cannot hear audio from any of those sources. I can see the video feed show up on my TV (via HDMI). I have tried modifying different settings that seem even relatively related via Web controls but haven't gotten anything to work. I have also tried different things from the Apple app. I also tried switching to different audio modes like Movie, Music, etc. Everything works perfectly via my old receiver so I know all of the cables and devices all work properly.
Any help will be greatly appreciated.
Here is data copied from Information:
AUDIO
Sound Mode DIRECT
Signal Analog
Format / /.0
VIDEO
Signal
Resolution --- >720p
Color Space --- > YCbCr 4:2:2
Pixel Depth
Monitor
Interface HDMI
Resolutions 480i/p
1080i:60Hz
720p:60Hz
1080p:60Hz
1080p:24Hz
ZONE
MAIN ZONE MAIN ZONE
Select Source NETWORK
Name NETWORK
Sound Mode DIRECT
Input Mode AUTO
Video Select Default
i/p Scaler OFF
ZONE2 ZONE2
Power OFF
Select Source SOURCE
Volume Level -40 dB
FIRMWARE
Version 1490-0168-0000-8540-2666
Post can be removed. I solved my own problem. I had to set the HDMI Audio Out to AVR and not TV.
Edited by CelebrateReuben - 8/12/12 at 1:57am
post #1419 of 7823
The take away from the above post for all new owners who purchase a demo, used, open box, or refurbished unit is to do the "reset the microprocessor" procedure listed near the back of your Owner's manual and in post #5 of this thread in order to return all settings to their factory default positions which would have alleviate the above issue.
post #1420 of 7823
the default button assignments in the Harmony setup are wrong. Don't just trust what Harmony "thinks" is right, you have to go into the button assignments for the Denon device and modify so D-Up/Down refer to the right commands. Harmony's will nearly always involve a bit of user tweaking to get things just right.
post #1421 of 7823
Originally Posted by batpig View Post
you should probably run a second HDMI cable from the AVR to another HDMI input on your projector and switch to that input when you want to access the Denons GUI for setup. You can setup through the front panel display but it's a pain, much easier to have the video feed. Another option which many use (if it's a problem to run that 2nd HDMI cable to the PJ) is to get a small secondary monitor (e.g. a cheap 20" LCD monitor) with HDMI input and use that for settings, so you don't have to fire up the PJ to make tweaks or run Audyssey.
the 1713 gives you the better XT version of Audyssey MultEQ, so I would say yes, it's worth it. If you want to save a few bucks and don't need the network features, you can get last year's 1712 for cheap as a refurb or closeout / open box. But since you have a PJ then I'm assuming it's a pretty nice setup, and having the nicer room calibration will be worth it.
Thanks for the info. Very helpful.
post #1422 of 7823
Updating *Problem" - no sound from HDMI after update, fixed with microprocessor reset
I just did the firmware update on the 3313CI. After I did, everything seems to go well, but a little later, no sound would come out of the HDMI, regardless of source (the two soured I was using were a Mac Mini and a Samsung Blu-Player). Sound from Optical and RCA worked fine.
I was able to fix it with a microprocessor reset -- Power On while holding Info and Back buttons.
Of course, I had to rerun the setup, etc, but at least it works.
Just wanted to post in case anyone else has this issue.
Update problem # 2 - Dialogue level grayed out
After I updated, the Dialogue Level option in the Audio menu is no longer accessible and is grayed out. It seemed to work pretty well, although I did not compared it against Reference Offset. Not sure why it's grayed out now....
Bhavesh
post #1423 of 7823
My AVR 1913 within the last few days has been unable to connect to Sirius XM Channels 840-856 under MLB Play-By-Play. It connected to these stations previously. My computer can connect to these stations through a wifi connection to the same router to which the receiver is connected by an ethernet cable. I find no other XM problems and everything else works well. Is anyone else experiencing this problem?
post #1424 of 7823
Unless someone posts of a similar issue, you may want to try unplugging the AVR for 10 minutes (soft reset) or if still no joy, resetting the microprocessor (p. 146 OM).
post #1425 of 7823
I have tried to search for this answer but can you setup Audyssey for normal 5.1 (7.1) Home theater and TV watching and then have a separate setting where the Audyssey is turned off for music, stereo 2.1 listening? My system is in my living room and servers double duty as home theater and our main stereo. I want to get a receiver that makes it easy for me to "switch" (seamless would be best) between TV/HT (Audyssey on) and then musics listening (Audyssey off and my own custom settings).
post #1426 of 7823
use a quick select... or just manually turn it off...
i'm not real sure why you want to turn audyssey off for music though, as your room does not make any distinction between "music" and "movies"....
post #1427 of 7823
Thanks ccotenj
1) If I setup these quick selects and one of those is setup with the Audyssey calibration, do I have to rerun Audyssey if I switch? (I would hope not)
2) I have heard that the Audyssey processing, dynamic eq and the like really messes with stereo music reproduction because the music is eq'd ot a different stand than movie soundtracks (i.e. reference levels) so I would like to have a HT setting and Music settings. I did not know if that is possible with the Denons. Im looking at the 2112 specially.
Thanks again.
post #1428 of 7823
1) no you don't have to re-run...
2) don't confuse "mix level" with eq... two different things... ignore what you have "heard"... you may have to use different dynamic eq offsets...
some things to keep in mind...
1) "audyssey" is really eq'ing the room/speaker interface... not just the speaker... and it is agnostic when it comes to content...
2) "dynamic eq" settings are then used to deal with various listening/mix levels to adjust for things like the fletcher-munson effect, and so on...
post #1429 of 7823
thanks... I can tell my ignorance is starting to show through now. =)
Bascially I want a clean stereo music setup and a balanced Home theater setup as well. I thought the concensous was that the auddesy room correct hurt stereo music but I may be wrong. What is the optimal settings then for stereo music? I have the Pioneer SP-FS51-LR setup for my 2.1 listening (pretty modest) but I still want good sound.
post #1430 of 7823
nope, it won't "hurt" stereo music... quite the opposite, actually...
"best" way, imo...
- set your speakers to "small"...
- set the xover to (at least) 80hz (do not lower it if the avr sets it higher)...
- use "stereo" with audyssey engaged... if necessary, play with the dynamic eq offset...
- do not use dynamic volume of any type...
post #1431 of 7823
"best" way, imo...
Thanks and would that be my calibration for everything when I listen to music and when I listen to music? Or Can I assign that calibration to some sort of preset, say "A", and have my hometheater setting on say preset "B"?
post #1432 of 7823
post #1433 of 7823
I have a newbie question about my incoming Denon AVR1613, arriving tomorrow. I've downloaded the manual to look over and I am unclear about internet/networking connections to the unit.
1) I currently have my cable tv coaxial cable coming into the room and plugged into my tv. Would it be better to hook the incoming coax to the Denon unit? The tv has HDMI which is how I'll be connecting it to the Denon.
2) I have wireless access in my home, but no close by hard wiring that could be run into the Denon unit. Do I need to get a wireless connection to make the Denon work with AirPlay? (I have seen a recommendation for Netgear WNCE2001-100NAS wireless adapter that looks like it would work.)
TIA,
Craig
post #1434 of 7823
I have a new odd issue with my 2113 all of sudden.
I'll be watching either my Blu-Ray or DVD players (they're seperate units on seperate inputs) and both cut out intermittently. I lose all image and sound suddenly and the screen has a weird black color to it (not the typical no-signal black). If the blu-ray does this, the screen never recovers, but when the DVD does this, it may come back on for a few seconds then do it again.
When I plug the blu-ray and DVD into the TV directly and bypass the denon altogether, both perform perfectly.
I've tried a hard re-set on the receiver, but the problem persists afterwards. I have an Extron control system controlling all my AV equipment, but I did not trigger any commands on it when the receiver cut-out. At first I thought it was an HDCP issue on the blu-ray, but for it to happen on the DVD player too (no-HDCP) is weird.
Anyone else experience this? Thanks.
post #1435 of 7823
TIA,
Craig
1. No. AVRs don't have TV tuners, so the cable must be plugged into either the TV or a cable/sat box.
2. There are several ways to connect the AVR, to include either via a wireless "bridge" as you noted and Powerline adapters that use the household wiring.
post #1436 of 7823
1. receivers don't have TV tuners, so the coax cable still has to go directly into the TV. Then audio will output to the receiver either by HDMI (if your TV supports ARC) or via the standard optical output from the TV.
2. yes, a wireless "bridge" will work fine for adding wifi functionality to your HT components
post #1437 of 7823
Try connecting each device to each of the other HDMI inputs and see if the problem still exists. If the BDP has a "Deep Color Output" setting, set it to OFF.
post #1438 of 7823
Thank you.
post #1439 of 7823
Thanks very much for the info and clarification. Really looking forward to the Denon setup!
I'm delighted to have found this forum.
post #1440 of 7823
Well my Denon 2113 arrived yesterday. I love it so far. The unit is much smaller than the hefty Onkyo it replaces. Best $407 i may have spent in my life. It sounds great with my Energy system. Was all set up and running easily. I guess it helped I read the manual waiting for it to arrive. Denon remote works great on iPad and Android phone. Airplay and Pandora are work rather nicely. Being a tech geek I like one more bit of hardware to play with. I hope to get Zone B set up on the back porch and try them out this weekend. I almost want another now for my home office if I can figure out an elegant way to get speaker wires to the front porch...lol
