ATV optical will work fine with the 4311. All music streams will be 2.0 PCM anyway. Some video content will be 5.1 DD but I doubt you will be streaming that to other zones.
AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ
Featured Stories
Topics Discussed
Related Forum Threads
- When do the 2013 Denon's come out? Any new features we should expect? Last post on 2/5/13 at 3:39pm in Receivers, Amps, and Processors
- Denon AVR-2313, AVR-2113/2112 AVR-1913 or Yamaha RX-V773, RX-V673 pls help to decide. Last post on 12/24/12 at 3:24pm in Receivers, Amps, and Processors
- The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread Last post on Yesterday at 2:56 pm in Receivers, Amps, and Processors
- The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] Last post on Today at 5:58 am in Receivers, Amps, and Processors
- Help Me pick a new TV Last post on 5/28/13 at 8:45am in LCD Flat Panel Displays
Related Articles
Denon 2011 and 2012 AVR FAQ, Setup, and Troubleshooting Guide
Edited on 9/13/12
Related Reviews
The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 9
Gear mentioned in this thread:
post #242 of 8300
5/24/12 at 4:33pm
- ccotenj
- Trader Feedback: +30
- offline
- 21,915 Posts. Joined 3/2005
- Thumbs Up: 79
- Select All Posts By This User
Originally Posted by morty343
I think an Airport Express to an analog input on a 4311 would be the only option, because if using an ATV, it would need to connect to the AVR via optical if I wanted to create "independent" AirPlay to Zone 2. The Denon manual states that if one wants to play audio from a digital audio input to Zone 2, it must be PCM 2.0 encoded, and it's unclear if one can "lock" an ATV's optical out to PCM.
I am not in a hurry to pull the trigger on a new AVR, so maybe a better bet would be for me to wait for the "clearance" pricing on the 4311s to get XT32.
i have been using an atv in the way you want for many many moons....
just out of curiosity... are you powering the zone from the avr, or are you using the preouts? if you are using preouts to a separately powered/volume controlled zone, just stuff an ax there, and you are done, don't even bother with zone 2...
post #243 of 8300
5/24/12 at 5:19pm
- hdSigmaChi
- Trader Feedback: 0
- offline
- 39 Posts. Joined 7/2010
- Thumbs Up: 10
post #244 of 8300
5/24/12 at 5:21pm
- jdsmoothie
- AVS Addicted Member
- offline
- 34,936 Posts. Joined 9/2007
- Thumbs Up: 356
post #245 of 8300
5/24/12 at 5:21pm
- morty343
- offline
- 50 Posts. Joined 2/2006
- Thumbs Up: 11
Yes I am currently using the preouts on my Integra DTR-6.5, and they feed into an older Russound home A/V distribution amp. You're right; I could feed an AX directly into an available set of inputs on it, but currently there are none. What I am picturing is the AVR's Zone 2 preouts going into the Russound amp, and I will use the AVR to switch between AirPlay (via AX), Rhapsody, and FM radio. Between the Denon app and Apple's Remote app I could control the various home audio zones with my iPhone, I believe...
post #246 of 8300
5/24/12 at 5:33pm
- 80sGuy
- offline
- 561 Posts. Joined 3/2006
- Thumbs Up: 10
post #247 of 8300
5/24/12 at 5:56pm
- jdsmoothie
- offline
- Thumbs Up: 356
post #248 of 8300
5/25/12 at 5:43am
- cybrsage
- Rebel w/o Applesauce
- offline
- 7,212 Posts. Joined 5/2007
- Thumbs Up: 42
post #249 of 8300
5/26/12 at 9:57am
- brouillet
- offline
- 8 Posts. Joined 1/2009
- Thumbs Up: 10
I know this topic has been touched on, but I'm still a bit confused. I have an Apple TV connected to my existing Denon AVR 2800 (yes, this is old), which allows me to enjoy 5.1 surround in the living room (speaker A) and also stereo on two separate speakers on the patio (speaker B). Turning living room speakers off and patio speakers on is as simple as a couple button clicks on the front panel.
I'm interested in upgrading to either 1713 or 2113 model, but am concerned whether I'll be able to:
1 - Send Apple TV audio (connected via HDMI) to the outside speakers (zone 2?)
2 - Easily be able to turn on/off inside and outside speakers depending on listening needs like I can today
I DO NOT need to play one source on Zone 1 and another source on Zone 2 simultaneously, if that makes a difference in the answer.
Thank you!
Thank you!
post #250 of 8300
5/26/12 at 10:12am
- Strider-
- offline
- 121 Posts. Joined 12/2010
- Thumbs Up: 13
Thank you!
Thank you!
1 - No, for some inane reason, no AVR on the market can do this. Also, the 3313 lost its ability to send PCM 2.0 (ie from the optical connector) to zone 2 as well.
2 - You'll have to check the manuals to see how far into the menus the speaker B control is. Note that this is not zone 2, so there might be some wierdness since you'll only have two channels rather than all 5.
post #251 of 8300
5/26/12 at 11:54am
- jdsmoothie
- offline
- Thumbs Up: 356
post #252 of 8300
5/26/12 at 12:10pm
- jdsmoothie
- offline
- Thumbs Up: 356
Thank you!
Thank you!
Any of the XX12 and XX13 Denon 7.1 AVRs (excludes the 1713 which is only 5.1) feature the "Front B" capability which can do the same thing as your 2800; however, the "Speakers" button is no longer on the front panel or remote so you must dig into the GUI menu to make the change unless you have a Harmony remote which can be taught the old Front A/B command.
1. As long as you only want the same capability as you currently have with the 2800 (ie. same source in main zone and Zone 2) then the "Front B" setup is likely your best recourse. Note however, the 1713 is only 5.1 and therefore does not feature "Front B" speakers. You might want to consider the 1712 as it is a 7.1 AVR with "Front B" capability. It also has custom STEREO settings which would allow you to setup STEREO to the "Front B" speakers and as long as you don't use STEREO in the main zone, anytime you change the surround mode to STEREO (easily done via the remote) it would switch to your "Front B" speakers.
2. See above.
post #253 of 8300
5/26/12 at 1:25pm
- Strider-
- offline
- Thumbs Up: 13
Everything I've read (from you and batpig) has said that it can only go out the zone 2 HDMI connector, which is more or less useless. If it can decode the audio and send it out the zone 2 speaker posts, I'd be ecstatic, but somehow I doubt that's the case.
post #254 of 8300
5/26/12 at 1:33pm
- jdsmoothie
- offline
- Thumbs Up: 356
post #255 of 8300
5/26/12 at 4:00pm
- brouillet
- offline
- Thumbs Up: 10
2. See above.
2. See above.
Thank you for the replies to my post. I was a little bummed to learn that digital sources could not be used using the actual Zone 2 functionality, but am glad to know there is a "Front B" concept that still exists and will work with HDMI connections.
Thank you for pointing out that the 1713 is a 5.1 system. I meant to say I was comparing the 1913 and 2113, with the main difference that seemed possibly relevant to me, being the better Audyssey XT feature. I just need to decide whether it's worthwhile.
I'm also intrigued with your comments regarding the 1712. Does the 1913 or 2113 offer that "STEREO" assign-ability as well?
post #256 of 8300
5/26/12 at 4:09pm
- highmr
- offline
- 31 Posts. Joined 3/2010
- Thumbs Up: 10
Some of the irritation here seems to be what is the purpose of the thread. From the title, it is mostly for owners to work on issues. Usually these threads are a lot of interest in the new features and whether the shiny new toys are worth getting. Part of that is how they compare to their predecessors and what else is out there. In 2010 I was happier getting a 2310ci and a blu-ray player hearing that 1080i component capability was on its way out but were still available on those models. In practice, I just use 1080i component for the cable box (less risk of HDMI handshake and to play music with a TV show) but even for that there are workarounds. So what might have seemed like a problem in 2011 or 2012 in retrospect hasn't been that big a deal for an average user. Today, you do have a clear situation where the 4311 is offering more than several years worth of next level down "improvements" can. So, if this is viewed as not so much a complaint at what the mass market wants but rather something to think about in terms of how high up the line to go or whether to get last year's high end model, it has some place in a purchase decision thread.
post #257 of 8300
5/26/12 at 4:28pm
- jdsmoothie
- offline
- Thumbs Up: 356
Correct. Analog only to Zone 2 is common to pretty much 98% of all AVRs on the market today. And the 7.1 AVRs to include the 1913 and 2113CI feature the A, B, A+B custom speaker settings to allow STEREO to be Front B only if desired.
post #258 of 8300
5/26/12 at 4:57pm
- Pilot625
- offline
- 8 Posts. Joined 5/2012
- Thumbs Up: 10
post #259 of 8300
5/26/12 at 5:16pm
- jdsmoothie
- offline
- Thumbs Up: 356
post #260 of 8300
5/26/12 at 5:44pm
- Pilot625
- offline
- Thumbs Up: 10
Great!! So from the standpoint of use. I want to be able to have surround sound with my theater and be able to stream music to a second zone. I'm not an audiophile but I don't want an annoying system that's difficult to use. Everything I have read is Denon is the way to go. Is the 2112ci enough for someone like me or should I get the 2113ci. The 2112 is now discounted pretty well with the new ones out.
I've always believed in getting the latest models but I'm not so sure here.
post #261 of 8300
5/26/12 at 5:49pm
- jdsmoothie
- offline
- Thumbs Up: 356
If using the on board Airplay to Zone 2 with a XX12 model (eg. 2112CI), the same source must also be selected in the main zone as well, whereas with a XX13 model (eg. 2113CI), you can play Airplay independent to Zone 2 with another source playing in the main zone. This limitation does not apply to other network audio sources not using Airplay.
post #262 of 8300
5/27/12 at 1:38pm
- Leef DaLucky
- Reluctant Hero.
- offline
- 209 Posts. Joined 1/2002
- Thumbs Up: 10
Hi folks,
I was just setting up an AVR-1913 for my aunt yesterday, and came across a problem getting the tuner section going.
I got the Bluray section and Cable section up fine, but when it came time to test out FM stereo I could NOT get a signal (or any sound at all).
When we switch to FM and tried to autoset the radio channels, it looked like the tuner was just setting every channel up small increments. It didn't even find some of the stronger toronto stations (104.5/107.1 etc).
And it wouldn't output anything when we manually tuned in (and pressed enter on remote).
It's like something in the antennae section is broken.
am I missing something?
thanks, in advance, for any advice you can offer.
This is running on a 3.0 speaker system.
L.
P.S. sounds pretty good so far from what i can hear. Lots of detail coming through.
L.
post #263 of 8300
5/27/12 at 1:55pm
- jdsmoothie
- offline
- Thumbs Up: 356
post #264 of 8300
5/28/12 at 6:39am
- Leef DaLucky
- Reluctant Hero.
- offline
- Thumbs Up: 10
post #265 of 8300
5/28/12 at 7:21am
- jdsmoothie
- offline
- Thumbs Up: 356
Use the SAVE/LOAD feature in Web Control (p. 89-90) to SAVE the config file to a PC (also use either Notepad or a hex viewer to ensure the file actually has data stored and is not all zeroes otherwise SAVE again if that is the case) and then reset the microprocessor (p. 146) to see if that resolves the issue.
post #266 of 8300
5/28/12 at 9:59am
- brouillet
- offline
- Thumbs Up: 10
I currently own an old Denon AVR 2800 and am looking to upgrade to the XX13 model year. At this point I've narrowed it down to the 1913 and the 2113CI. Honestly the only thing making me keep the 2113CI in the running is the fact that is has the Audyssey MultiEQ XT instead of the the MultiEQ (1913). The extra year of warranty is certainly a nice to have, but even that isn't that big of a deal to me. Now, if the 2113CI was truly built on a "nicer" platform that would be more compelling, but I gather this is not the case. I know the two units are priced within $70 MSRP -- not sure what the difference is in real-world pricing...
Coming from an old AVR 2800 Audyssey in any flavor would be a welcome improvement, but I don't know whether going the extra mile to get the XT version is worthwhile given I don't upgrade AVRs very often (7-10yrs). One other possibility would be to wait and see if the XT32 variation continues to work its way down to the 21XX for the XX14 model year since I understand the XT32 is quite a leap forward.
Bottom line is my speaker setup is nothing fancy (in-walls/in-ceiling fronts/rears that came with the house, and a Polk sub and Polk front channel I added) so that may play into the strategy.
Any thoughts/perspective would be most welcomed.
post #267 of 8300
5/28/12 at 10:29am
- jdsmoothie
- offline
- Thumbs Up: 356
The upgrade to XT might only provide a nominal increase in audio fidelity, however, in the end, the decision always comes down to budget. Another thing to note though is that the 1913 does not have Zone 2 preouts. Originally I never planned on Zone 2 speakers, however, would later come to appreciate Zone 2 preouts in which I connect a set of wireless headphones so I can listen to an independent audio source in my office while the main zone is used for another source. If you don't ever see a need for the additional features provided by the 2113CI, get the 1913 and enjoy.
post #268 of 8300
5/28/12 at 11:46am
- brouillet
- offline
- Thumbs Up: 10
Thanks for sharing your thoughts on this. I hadn't thought about the Zone 2 Pre-out angle, thank you. So, I take it with that, one can hookup powered/wireless headphones/speakers without needing to have a dedicated, second amp? If so, I assume the Zone 2 limitations still exist that I had posted (and you replied to) already earlier this weekend?
post #269 of 8300
5/28/12 at 12:04pm
- jdsmoothie
- offline
- Thumbs Up: 356
post #270 of 8300
5/28/12 at 6:41pm
- swizzchard
- offline
- 255 Posts. Joined 4/2012
- Thumbs Up: 10
Originally Posted by batpig
eyeballing the 3312 vs. 3313 photos and spec sheets, this is what I can see:
LINK TO DENON SPEC SHEET COMPARISON
The same:
* Same size, same power (125w/ch x 7)
* The input/output allocation is nearly identical:
--- Both have 11 speaker posts but only 7.2 ch pre-amp outputs (i.e. can connect + EQ 11 speakers but only 7 active at a time)
--- Both have 6 rear HDMI inputs
--- Both have 1 front HDMI input, 1 front USB input, and front panel RCA input (R/L stereo + composite video)
--- Both have dual HDMI outs (parallel) for main zone
--- Both have 2 component video inputs + 1 output, and 2 digital coax + 2 optical audio inputs
--- Both have Zone 2 + Zone 3 pre-outs and one analog REC OUT
--- Both have RS-232, two 12v trigger outs, and room-to-room IR jacks
--- Both have six analog audio inputs (excluding the "DOCK" input that disappears) including a PHONO input
* Both have "advanced GUI" and analog>HDMI video conversion
* Both have networking with Airplay support etc.
* Same DAC's and ADC and DSP chips
* Both have AL24 processing on FR/FL channels only
* Both have the same Audyssey package (MultEQ XT + Dyn EQ/Vol + DSX)
3313ci losses vs. 3312ci:
* No more iPod "Dock" input with control port (obsoleted by Airplay + USB options)
* No more S-video inputs
* One fewer composite video input
* Networking drops Rhapsody / Napster support
* New "simplified" remote cannot be programmed to control other devices
* No more AM radio tuner (although the HD tuner supports AM where available)
3313ci gains vs. 3312ci:
* Zone 2 matrixed HDMI output
* 4k video scaling
* DenonLink HD
* AirPlay independent to Zone 2
* SiriusXM and Spotify (coming via firmware update later this summer)
* Aluminum faceplate with drop-down door hiding front panel controls
* Hidden front panel controls include D-pad + buttons for setup menu access (meaning you can set it up without the remote unlike the 3312)
(plus the unconfirmed possibility that the 3313ci loses the digital>analog ability for 2.0 PCM output to standard Zone 2, but wait for the manual to appear before panicking)
The same:
* 4k video scaling
* DenonLink HD
noticed the discrepancy of the pcm based on first page FAQ and mixed in the threads. any confirmations yet?
- The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ
Currently, there are 1986 Active Users
(521 Members and 1465 Guests)
Recent Discussions
- › Official Vizio M-Series Razor Mxx1i thread 41 seconds ago
- › Bizarre prices on Ebay 50 seconds ago
- › Atlantic Technology owner's thread. 1 minute ago
- › List of HDTV's with 120Hz native refresh ability (forcing... 1 minute ago
- › How Does Watching Movies in Your Home Theater Affect How Often You... 1 minute ago
- › NAS as HTPC? (XBMC on QNAP TS-x69s) 1 minute ago
- › Bookshelf speaker recommendation for $400 budget for the pair in a... 1 minute ago
- › October fun: 31 days of Horror, Blood, Guts and Gore! (and zombies,... 1 minute ago
- › AE Group buy 2013! 1 minute ago
- › Best 2-zone receiver for the money - impedance matching controls 2 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Sony BDP-S5100 3D Blu-ray Disc Player with Wi-Fi by imagic
- › Yamaha Aventage Blu-ray Player Black - BD-A1020 by foursticks
- › Panasonic DMP-MST60 Smart Network Media Streaming Player with... by amesdp
- › Sonax E-0062-BF Fiji 60-Inch TV Component Bench, Ravenwood Black by DDT0C
- › OPPO BDP-93 Blu-ray Player by KingLeerUK
- › Sony Blu-ray Disc Player - BDP-S790 by wisccheese
- › Samsung BD-C6500 1080p Blu-ray Disc Player by NeonSignedOff
- › Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player by bettzysdaddy
- › Panasonic DMP-BD65 Blu-Ray Disc Player (Black) by dasher123
- › Where's The Wires, LLC Streaming Media/Soundbar Power tool by wheresthewires
View: More Reviews
New Articles
- › Why is LED light known as long life by Davidsmith001
- › Blu Ray Player Review Contest by Mike Lang
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
