JD seems to be speaking of it as though it's factual so I assume he heard this from an inside source. I would like to see it in the manual though before I call it "confirmed".
AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ
Featured Stories
Topics Discussed
Related Forum Threads
- When do the 2013 Denon's come out? Any new features we should expect? Last post on 2/5/13 at 3:39pm in Receivers, Amps, and Processors
- Denon AVR-2313, AVR-2113/2112 AVR-1913 or Yamaha RX-V773, RX-V673 pls help to decide. Last post on 12/24/12 at 3:24pm in Receivers, Amps, and Processors
- The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread Last post on Today at 6:44 am in Receivers, Amps, and Processors
- The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] Last post on Today at 7:22 am in Receivers, Amps, and Processors
- Marantz NR1603 vs Denon AVR-1713/AVR-1613 for stereo use. Last post on 2/18/13 at 8:39am in Receivers, Amps, and Processors
Related Articles
Denon 2011 and 2012 AVR FAQ, Setup, and Troubleshooting Guide
Edited on 9/13/12
Related Reviews
The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 10
Gear mentioned in this thread:
post #272 of 7818
5/29/12 at 12:21pm
- jdsmoothie
- Trader Feedback: 0
- AVS Addicted Member
- online
- 34,371 Posts. Joined 9/2007
- Select All Posts By This User
Although Denon is coming out with a new Android REMOTE app soon, if any of you new XX13 model owners has an android phone, can you check whether the current AVR-REMOTE app works with your unit? Thanks.
post #273 of 7818
5/29/12 at 12:52pm
Hi jdsmoothie. Just installed the AVR-REMOTE app on my desire S and it was able to conect on the AVR generic. I am also able of playing my music stored on the HTC. I have to use the AVR App to control volume, i can not do this from the phone volume buttons as i can on my Iphone via airplay. Funny how i can play with both phones via the apps without having problems. However the AVR-Remote app will not let me select the input. This works fine on my Iphone, But maybe i am doing something wrong.
My model is a 1713
My model is a 1713
post #274 of 7818
5/29/12 at 1:02pm
- jdsmoothie
- online
post #275 of 7818
5/30/12 at 7:33am
Hi guys, got my Denon 1713 set up yesterday (just as a stereo system for now until my qed cable arrives).
But I have a problem, when I connect my iPhone to it via the front USB it shows up fine and can play music etc but when I connect my Toshiba 2.5" 1TB Stor.E Alu S2 HDD it doesn't power on, but in the 1713 manual it says;
Only USB memory devices conforming to mass storage class and MTP (Media Transfer Protocol) standards can be played on this unit.
This unit is compatible with USB memory devices in FAT16 or FAT32 format.
My drive is formatted to FAT32 and does not exceed the limits which are mentioned in the manual;
Memory capacity FAT16 : 2 GB, FAT32 : 2 TB
Number of folder directory levels * 8 levels
Number of folders 500
Number of files ** 5000
* The limited number includes the root folder.
** The allowable number of files may differ according to the USB memory device capacity and the file size.
The drive uses USB 3.0 (which is 2.0 compatable) and it is also a USB powered drive which is why I bought it, so I can switch between PC and AVR quickly.
Am I missing something?
post #276 of 7818
5/30/12 at 4:49pm
- mazer75
- offline
- 85 Posts. Joined 5/2008
I have what will probably seem like a dumb question to most of you experts, but here it goes.
I am going to buy either the 1713 or 2113CI to replace my dying receiver, and at the same time I'm going to replace my antiquated subwoofer.
My question is this: are either the 1713 or 2113CI capable of outputting via LFE, or do they only output a line level subwoofer signal? Some of the cheaper subs don't have LFE input, but I am not sure I even need to care if the receiver is not capable of outputting it.
Thanks for the help!
- batpig
- terrorist and rioter
- offline
- 21,142 Posts. Joined 2/2007
your question doesn't really make sense, I don't know what "output via LFE" even means.
ALL modern receivers output the subwoofer signal via an RCA variable level pre-out with the intention of being fed to a powered (amplified) external subwoofer, and ALL modern powered subwoofers have RCA inputs intended to receive this signal. So I think your concerns about compatibility are unfounded
The subwoofer output will be combination of the LFE track (the ".1" in 5.1 or 7.1 tracks) and any redirected bass from speakers set to "small", which will feed out the SUB OUT jack into the RCA input on the subwoofer to be amplified.
post #278 of 7818
5/30/12 at 4:59pm
- mazer75
- offline
ALL modern receivers output the subwoofer signal via an RCA output with the intention of being fed to a powered (amplified) external subwoofer, and ALL modern powered subwoofers have RCA inputs. So you are fine
Ah, you are FAST!
Well, my information is probably wrong, but I was reading in amazon.com ratings/comments that for receivers that are capable, a subwoofer with an LFE input is better because using it will bypass the internal crossover in the sub. Then the receiver will set the crossover frequency directly. Presumably the benefit would be better sound.
If you look, cheaper Polk subwoofers like the PSW10 are not LFE-capable, however their more expensive models are.
Thanks for your response!
- batpig
- offline
ok, there's some confusion in terms here.
some subs have an additional input labeled "LFE" which does indeed bypass the internal circuitry (crossover/volume), but this does not mean that subs without this input aren't "LFE capable" (like I said above this doesn't really even make sense). Marketing labeling can be confusing when they aren't consistent with their terminology.
Bottom line: ALL subwoofers will work just fine with the sub out RCA signal from a modern receiver even if there is no direct/LFE input jack. All you have to do is follow the subwoofer setup instructions here and you will be fine: http://www.audyssey.com/audio-technology/multeq/how-to
post #280 of 7818
5/30/12 at 5:27pm
Is anyone having a problem with 1 or more of their HDMI ports not working??
I just received the 1713 about a week ago and It seems my (cable) HDMI port will not transfer video or sound. I hook my cable box up to it and I get nothing. I then hook it up to my DVD port and it works fine.
Does this sound like a faulty port???? I hate to have to send it back since the pioneer 821 I bought before the Denon didnt work out of the box, dont want to go through that again.
What would you guys do? Still have 4 ports to work with on the back??
post #281 of 7818
5/30/12 at 5:28pm
- mazer75
- offline
And just to defend myself, here is what I'm talking about
http://www.polkaudio.com/homeaudio/p...ex.php?s=psw10
Check the text on the page:
Multiple Hook Up Options LFE*, line level inputs and speaker level inputs afford easy connection to any system.
*Except PSW10 & PSWi225
So that was what set me down this path of misinformation
post #282 of 7818
5/30/12 at 5:32pm
- mazer75
- offline
Awesome, thank you!!! I will read up and be ready for my new receiver. Thanks again!
post #283 of 7818
5/31/12 at 4:18am
- jdsmoothie
- online
This has been common to Denon AVRs for several years ... some components work better on one HDMI jack vs. another due to the various signal lengths on the HDMI board. Also note that cable/sat boxes often have HDMI handshake issues and must be connected directly to the TV to work correctly so at least yours works connected to the AVR. I would confirm that another HDMI device works when connected to the CBL/SAT and call it a day.
post #284 of 7818
5/31/12 at 4:23am
- jdsmoothie
- online
However, if you look at the PSW10 Owner's manual and review the Note under option #1 ....
The PSW10 subwoofer does not have an LFE input. Instead, use either the L or R Line input (another hookup option is to use a Y-split cable and connect both L and R Line inputs). After you make this Sub Out connection, turn the "Low Pass" filter fully clockwise. This will in effect create an LFE input.
post #285 of 7818
6/1/12 at 1:11am
- Phantom Gremlin
- offline
- 1,403 Posts. Joined 8/2002
I think this needs clarification. It sounds very negative.
1) the 3313ci back panel has an "AM LOOP ANT" input.
2) the spec sheet says "AM section Tuning frequency range 530 - 1710 kHz"
To me that means an "AM radio tuner". Are you trying to say it instead has an "HD radio tuner", one of whose operating modes is backward compatible with what we have known for decades to be AM aka "amplitude modulation" radio broadcasting?
post #286 of 7818
6/1/12 at 1:20am
- 80sGuy
- offline
- 561 Posts. Joined 3/2006
- batpig
- offline
post #288 of 7818
6/1/12 at 8:29pm
post #289 of 7818
6/1/12 at 9:35pm
- jdsmoothie
- online
If you look on the back of the AVR, you'll note the analog inputs are color coded ... the component video (green, red, blue), composite video (yellow), digital coax audio (orange), composite audio (red/white) and Zone 2 pre-outs (red/white). So you would connect a red/white RCA cable from the Zone 2 pre-outs to a 2CH external amp if you have a 7.1 setup in your main zone and want to setup Zone 2 speakers. However, if you only have a 5.1 setup in the main zone, you can connect the Zone 2 speaker wire/banana plugs to the Surr Back/Amp Assign speaker posts which default to Zone 2 out of the box.
post #290 of 7818
6/1/12 at 9:41pm
Thank you!!! That's what I was hoping for. Off to purchase 2113ci.
post #291 of 7818
6/2/12 at 7:35am
- 1080P Input
- offline
- 324 Posts. Joined 11/2005
Jd, I am looking at this same setup and am running 7.1 in the main room. Would I be able to do the 3113 and get the 2 outdoor speaker wires into the other speaker inputs so I can avoid getting a 2ch external amp for the 2 outdoor speakers? Also, how much is a 2 ch external amp and is there one you recommend to run for outside zone 2 speakers?
post #292 of 7818
6/2/12 at 7:42am
- jdsmoothie
- online
I'm presuming you mean 2113CI vice 3113CI? And no, if you have a 7.1 setup in the main zone, you must use a 2CH amp connected to the Zone 2 preouts. You can likely pick up one from your local Craigslist for $50 or less or you can buy one new. Please review the Zone 2 section in my FAQ in post #3 below:
http://www.avsforum.com/avs-vb/showt...p?p=20422390#M
post #293 of 7818
6/2/12 at 7:53am
- 1080P Input
- offline
Thanks Jd!
post #294 of 7818
6/3/12 at 11:39am
One of the features of the xx13 AVRs is conversion to 1080p/24Hz. The manual for the 2312ci implies that the receiver will pass a 1080p/24 signal through when the connected display supports 1080p/24. So that means I can watch a bluray at 1080p/24, right?
Why is it important to be able to convert to 1080p/24, then?
post #295 of 7818
6/3/12 at 12:02pm
- ccotenj
- Trader Feedback: +30
- offline
- 21,915 Posts. Joined 3/2005
yes, you can...
as to why it's "important"... if you are sure you have a film source, and you have a display that will display 24 frames per second in integer multiples (and won't do the reverse pulldown to 24 fps), you can eliminate 3:2 pulldown judder (which most people have been looking at their whole lives, and wouldn't know it's a problem until told there is one)...
post #296 of 7818
6/4/12 at 7:12am
- cybrsage
- Rebel w/o Applesauce
- offline
- 7,005 Posts. Joined 5/2007
Agreed, then you write the info down in your manual in case you need to disconnect things.
HTPCs needed to be plugged into the HDMI port closest to the HDMI Output port on the 3808CI in order to work at all.
post #297 of 7818
6/4/12 at 7:49am
post #298 of 7818
6/4/12 at 8:32am
- jdsmoothie
- online
Both the 2313CI and 3313CI should be available by mid-June, although if you only paid $1100 for your older AVR, you most likely won't be "downgrading" audio quality with either model as they both use Audyssey MultEQ XT.
Most often places recommended to purchase are AV Science Store, Electronics Expo, J&R, and World Wide Stereo which are all authorized Denon resellers.
post #299 of 7818
6/4/12 at 9:15am
I searched all the troubleshooting posts, and I am still stuck on why my Blu-Ray player won't play through my receiver via HDMI. My HDMI cable/tv connection plays fine and I have checked the Blu-ray player using the other inputs to no avail, and have ruled out the HDMI cable itself. The weird thing is it plays the audio when the tv imput is switched to another empty/vacant source. Also on initial startup of the Blu-ray it shows the Sony and Blu-ray logos, then the screen goes black.
I have two HDMI inputs on my tv, so I'm lucky that I can still connect it directly to the other input of my tv and will have to get an optical cable for connecting audio to my receiver.
Does anybody know of any similar issues and fixes? I'm thinking its a setting within my Blu-Ray player, but I've tried changing just about every setting with no luck.
post #300 of 7818
6/4/12 at 9:22am
- Selden Ball
- offline
- 4,363 Posts. Joined 1/2001
- The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ
Currently, there are 1646 Active Users
(372 Members and 1274 Guests)
Recent Discussions
- › The New PQ Tier thread for Blu-Ray - Discussion 37 seconds ago
- › What differences will I notice if I do a major speaker upgrade? 40 seconds ago
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 1 minute ago
- › Onkyo TX-SR707 No Sound - Add me to the list 2 minutes ago
- › Yamaha 720 Receiver 2 minutes ago
- › Dual Rythmik FV15Hp`s/upgrade to diy? 2 minutes ago
- › Trailer: Tom Cruise's "Jack Reacher" Thriller 3 minutes ago
- › ZT60 Series, Shipping May 2013, Models/Sizes/List Prices 3 minutes ago
- › #### The ULTIMATE Bass Demo Disc #### 3 minutes ago
- › BD370/390 LG Blu-ray player Master/Owners thread 4 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
