AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ
The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 132
post #3931 of 10468
Originally Posted by ray587 View Post
I just bought a nee 3313 to rrplace a 3803. What I want to know is can I use a wireless doggle or adapter to make this thing wireless
Sorry, but no.
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100#user_G2
post #3932 of 10468
Originally Posted by pmcl77 View Post
Hi,
first it seems Quick Select has been dropped on the 2113/2313 compared to 1912/2312. Is it tru, that the settings that used to be be set in quick set (like input, sound mode, audyssey) is now just saved for each input?
Further, It seems the seperate 2ch-speaker-setup has been dropped on the 2113/2313 compared to 1912/2312 and now I would have to go for a higher end model to get that. For me it's important to be able to quickly turn down/off the sub while watching a movie (or listening to music, though in 2ch I prefer no sub anyway). I guess I can just go into Menu/Audio and do both, adjust level or turn it on/off?
Phil
1. Although the Quick Select buttons have been removed from the remote, they are still accessible via the front panel.
2. Correct. The custom 2CH settings have been dropped from the 2313CI and lower models (only avail on the 3313CI).
post #3933 of 10468
Originally Posted by jdsmoothie View Post
So you're saying that when 2CH playback is set to "A" only the sub works, but when set to A+B, the sub doesn't work?
no...when 2CH playback is set to "A" sub works and when set to a+b sub works...sub does not work when set to B (all of this when amp assign is frontB)
post #3934 of 10468
So then ...as I suggested ... you can simply use the A+B setting and disconnect the Front A speakers. This is much easier when using banana plugs.
post #3935 of 10468
I have ordered my 3313 it will be here by Christmas....so it won't connect wirelessly to my home network?? It won't be able to do firmware updates or be controlled via Roomie or stream content unless it has a wired connection? Damn I've done so much reading on the 3313 my head hurts, overlooked this. Do not have Ethernet in my theater and just had to get directv's wifi transceiver to network the directv receivers in order to allow Roomie to control them. I hate this hobby/addiction.
post #3936 of 10468
You apparently didn't read the link I posted.
post #3937 of 10468
Dude I've read every one of your posts! Lol...you're work is appreciated and part of the reason I'm upgrading my older Denon to the 3313 so take it easy biggrin.gif...looks like a wireless bridge is needed, I could also then have my Oppo bdp-103 wired from bridge as well.
post #3938 of 10468
http://www.amazon.com/Netgear-Universal-Range-Extender-WN2500RP/dp/B006V72AHC/ref=sr_1_1?ie=UTF8&qid=1355673772&sr=8-1&keywords=netgear+wireless+extender
That's what I use and it works great. It extends your wi-fi network and has 4 LAN ports to pull ethernet from the wireless signal
post #3939 of 10468
My solution to Internet connection was to use plug an airport express near the Denon AVR and make an ethernet connection from Airport express - software updates work well. You could try a similar solution
post #3940 of 10468
Thanks for the replies everyone.
post #3941 of 10468
This could be part of a design philosophy change, where Denon expects the "B" speakers to be in another room or secondary setup. They probably got a lot of complaints from people who switched to their "B" speakers and were like, why is my sub still going boom boom in the living room?
Added to the removal of the 2ch custom settings from mid level models... there seems to be a design shift hsppening. The 4520 owners have reported that the 2ch custom settings are only active in the 2ch/B type configurations, where you switch to a completely different pair of speakers for dedicated 2ch listening.
In fact, could a 3313 owner test this? Are the 2ch stereo/direct custom settings grayed out? On the 4520 they are grayed out unless amp assign is set to "FrontB" or "2CH" modes.
post #3942 of 10468
Just to confirm ... you're trying to Airplay the video to the ATV2 directly and then have the ATV2 pass the video via HDMI connection to the AVR, correct? As the on board Airplay will only pass audio.
With the ATV2 also connected via an optical cable and that optical cable source selected for audio, you should then be able to use the "Video Source" setting to select the component video input.
When I try this, it's still the ATV2 on the screen. I'm havnig a tough time getting the component dvd to show up, even when dvd is selected as a video source.
post #3943 of 10468
Question about zones: I'm looking at the 3313 and loving the matrixed HDMI 2 idea for zone 2 (bedroom). I also have wired speakers outside. My main setup is 5.1, would it be possible to have the extra 2 channels power my outdoor speakers as zone 3? Or are pre-outs my only option for zone 3? Thanks for all the great info and details on this line of Denons!
post #3944 of 10468
I have searched the thread and found at least one person had this issue. While watching my Uverse, the sound sould dip down for a sec or two then normal. Receiver is up to date. Didn't see any solutions. I didn't know if anyone else is experiencing the issue or know a fix for it. (2113)
post #3945 of 10468
If you have Dyn Vol enabled, try turning it OFF.
post #3946 of 10468
Yes, as noted on p. 93 in the Owner's manual, the AMP ASSIGN setting for the extra 2CH can be set to Zone 3 to power your outdoor speakers. smile.gif
post #3947 of 10468
If you also are using DVD for an HDMI source, try setting the component video input to an unused source.
post #3948 of 10468
Awesome--I'd missed that. Thanks JD for all the great info and posts! smile.gif
post #3949 of 10468
I dont have any HDMI coming from teh blu ray player. Another annoyance about my denon is there is an HDMI handshake issue with my blu ray which is why i have to use components. I called denon, and they said, sometimes this just happens..either use components or buy a new dvd player...very helpful. In any event , still no dvd while listetning to music via ATV.
post #3950 of 10468
DId you try connecting the DVD(HDMI) to every HDMI input on the back panel to see if one works better than another as they are not all created equal? Also, DVD(HDMI2) defaults to "HDMI" out of the box, so try setting it to "None".
post #3951 of 10468
This is exactly what I'm doing. The extra 2 amplifiers are assigned to zone 3 (though in my case, the bathroom, but same idea).
post #3952 of 10468
post #3953 of 10468
i tried this ..no luck. I'm confused. Is the issue b/c i have ATV hooked up to media player via HDMI? Is this the reason I can't use DVD as a video source?
post #3954 of 10468
Well, it's more for listening to the news and morning shows while in the shower. wink.gif
post #3955 of 10468
Hi all. Long time lurker but it's time I posted.
Firstly I love this forum, it's been extremely helpful. Love the 3313 too but...
I need some help with Zone 2 (groan). Basically my whole signal path is digital. Got my blu ray player audio working on my zone 2 TV using the L and R analog outs from the player (main zone is a projector, tv is in another room). Now my issue is the Xbox 360. It's HDMI and I can get an audio adaptor with digital and analog outs on it. The problem: is how do I get the audio into the receiver, out to the zone 2 speakers? Video is fine, but the "Game" HDMI input doesn't have a corresponding analog audio input like the Blu Ray input does.
Anyone got a solution for this? Or will I just have to use another HDMI input, like "DVD" for it to work? I'd really love the Xbox to be accessible via the Game button on the remote though.
Should have gotten the 4520 to get the digital inputs on zone 2!
Thanks for your help!
post #3956 of 10468
If you're using the HDMI input for audio, yes ... which is why I indicated you would also need to have an optical input and using that input source for your audio input when you wanted to view another video source.
post #3957 of 10468
Bingo! You'll need to assign the xBox HDMI to another source name that matches one of the unused analog audio source names. Note that the 4520 has the same "no digital to Zone 2" limitation.
post #3958 of 10468
I can't tell by your reponse whether or not you found a solution that works or you were just thanking people for their responses. Just to make sure, yes, you can, but not the way you initially intended. jdsmoothie's link showed a couple of choices. Here's another that should work.... http://homestore.cisco.com/en-us/adapters/linksys-WET610N_stcVVproductId65221232VVviewprod.htm#self
IMHO, if you can go wired, I'd do it, because you get the maximum network speed.
post #3959 of 10468
JD, thanks for taking the time. Let me explain my exact setup.
I have ATV2 HDMI going into "Media Player" input.
I have my optical audio going from ATV to optical input on receiver.
Blu Ray Player hooked up via Component to DVD input on AVR ( I am using components b/c it says "no signal" when I use HDMI
I go to Input assign, for Media Player , I changed HDMI to None, and Optical to OPT 1.
Then I click on video source, I select DVD.
The screen goes black for a seconf then back to the ATV menu. Sounds like it's set up the way u are suggesting but isn't working?
post #3960 of 10468
Loving my 1713! I decided it was time to get a universal remote. I picked up a Harmony 650 for a little over $50. I am very impressed. It controls my Visio tv, Roku XS, Panny DVD/Recorder, Dish 211K and of course the 1713. The only thing that does not work is the 4 mode buttons. I tried the button programming in the Harmony setup but no go. Then I tried the learning setup and that did not work either.
I thought I would ask here first since there are really smart people here!
