AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ
The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 147
post #4381 of 7833
Originally Posted by jmoakk View Post
Do these models allow you to display the volume on screen when using hdmi? I'm looking at the 1713 or 2113.
My 591 can not do this :-(
Sent from my SAMSUNG-SGH-T769 using Tapatalk 2
The 1613 and higher models can all display the GUI over 2D/3D video.
post #4382 of 7833
@TerpCJ -
As noted in the post you quoted, only the 3313CI remote will control other devices; however, you are much better served replacing the 2113CI remote with a Harmony remote which can then control all of your devices to include the 2113CI. smile.gif
post #4383 of 7833
Originally Posted by ceh383 View Post
To be honest, I've owned several receivers over the years and I never had to turn them up past 50% for them to ROCK. The 125wpc (rated) of the Denon vs the 90wpc (rated) of the Sony is about a 40% increase in power, it is surprising to have to turn it up that far... It is without a doubt "cleaner" than the Sony.
My wife woke up, and I did turn it up....75 ~ 80....it came alive.
Given past experience it just didn't seem right....
Thanks all....
you're not using the receivers full potential... run audyssey - I'm sure you'll be able to tell a difference. I haven't had a chance to run it on mine yet and I notice the same thing you do. Dynamic EQ will probably address those issues you're perceiving.
post #4384 of 7833
My surrounds should arrive tomorrow, I'll have them hooked up by the weekend....Then I will run audyssey, and dial it all in, well, at least begin to dial it all in....
I setup a couple internet radio stations today, and it seems they don't need turned up nearly as far to get the volume out...I may need to turn up the other input sources...
It's going to take some time to dial it all in, there's a lot more to deal with than I had with the old system...
Edited by ceh383 - 1/1/13 at 5:10pm
post #4385 of 7833
To be honest, I've owned several receivers over the years and I never had to turn them up past 50% for them to ROCK. The 125wpc (rated) of the Denon vs the 90wpc (rated) of the Sony is about a 40% increase in power, it is surprising to have to turn it up that far... Given past experience it just didn't seem right....
Thanks all....
I've had the same frustrating experience with my Denon 2313. My old Kenwood KR-V8010 seems to have a lot more punch. I ran the Audessy to begin with and I find it actually sounds better with more bass when I use the "pure" function, which is much like the Direct CD function on my Kenwood. I wish it had an equalizer that I could manually adjust. I've got 15" subs in my 4 way floor speakers and they seem useless on the Denon. With the Kenwood movies would come alive and music I could rock the place out with no distortion.
Seems as if I have to buy a sub to get the same experience with the Denon and that should not be the case.
Edited by SundayMoney - 1/2/13 at 8:10am
post #4386 of 7833
sorry for the duplicate
Edited by SundayMoney - 1/2/13 at 7:42am
post #4387 of 7833
Hi
Do any of you guys have the 3313 AVR/DBT combo?
I'm really interested in hearing about sound from movies via Denon Link HD
Is it noticeably better than sound via HDMI?
Any thoughts would be greatly appreciated
Jakob
post #4388 of 7833
Originally Posted by marinated View Post
Here is my solution;
1. My cable modem is upstairs and it is hooked to apple time capsule (backup +base router/wifi) and I have an airport express plugged near Denon connected via ethernet. Works great and No issues with software downloads.
2. I run HDMI from cable box to AVR. A similar setup would work
Most of the times, AVR when I turn on TV and cable-box (depends on HDMI handshake sequence as I understand). If the receiver turns on and I do not want it, I just turn off the Denon and the audio comes from TV speakers (there is a couple of seconds delay)
You might want to checkout the nice setup guideline at the beginning of this thread... was very useful to navigate through various options
Good Luck
Thanks Marinated! I'm actually thinking of running a CAT5 cable under the crawl space once I looked at prices on monoprice.
post #4389 of 7833
Have you run Audyssey yet? Do you have a subwoofer? If so, Audyssey has probably set the crossover for your FL/FR speakers higher than you are used to, and may have set your fronts to "Small". You can do one of two things: set your front speakers to "Large" or lower the crossover point. Either should help your fronts output more bass.
post #4390 of 7833
Thanks all....
Did you change your volume display to the DB meter style as recommended? If you did, as you get closer to 0db (reference level) it should be plenty loud. Most higher-end AVRs and amps have used the DB scale for quite some time now so the user would know when they were at "reference level", it is just now starting to trickle down to the mid/lower end components.
post #4391 of 7833
Here's a question for the Denon pros:
I know it's a bad idea to let Audyssey set your subwoofer level to more than +12db or less than -12 db, and I got that figured out - I had to turn the volume knob on my Velodyne F1500 to about 1.5 (out of 10) to get it at -3db. smile.gif
Anyway, I'm running Klipschorns for my FL/FR speakers and as you probably know, they are VERY sensitive. When I run Audyssey, it sets my front left to -12db and front right to -11.5db. I'm worried that the -12db on the FL is messing up my Audyssey calibration - anything I can do about this (short of getting different speakers)?
What I've done in the meantime is to get out the trusty Rat Shack db meter and set the speaker levels manually so that they all match, using the FL speaker's level as the reference. When I do this, I have to turn up the center and surrounds a bit (maybe 2db or so) to get the same level as the FL.
Is all of this messing up the Audyssey calibration?
post #4392 of 7833
Yes the speakers are set for large. I do not have a subwoofer, although it said I did. Just changed that to no.
Guess I have to run Audessey again? Thanks for the assistance, I appreciate it.
post #4393 of 7833
Are the woofers on your mains fed by a sub out? Are they powered? Some are....
Yes, any time you change speaker configuration (i.e. telling the Denon you have no sub), you should re-run Audyssey.
Strange that the Denon would say you have a sub if you have nothing hooked up to the sub out, though. Do you hear test tones when it says it is detecting/measuring the subwoofer?
post #4394 of 7833
Also, make sure you run at least 3 listening positions (more is better) with Audyssey. And, make sure you are using a tripod or some other stable base for the mic.
post #4395 of 7833
Warranty.
I contacted Denon this morning and they 'may not' honor the warranty if the unit is purchased from a Non-authorized Vendor. According to the rep, there is sometimes a problem with fraudulent serial numbers on some units. I don't know how that could happen and he could not explain it to me. But if you have a Denon AVR-3313ci, I would think that it has to be made by Denon. Why would anyone buy a new unit and change the serial number? Anyway, it was still enough to scare me away from the vendor that has the unit, delivered, for $858, and I purchased it from an 'authorized' dealer for $910 delivered by FedEx in 3 business days. The extra $52 is for my peace of mind.
Edited by clev1 - 1/2/13 at 9:46am
post #4396 of 7833
I just purchased the AVR-1913 and got everything working fine, however when I set the input to my PS3 I don't have very many surround modes. There's just Stereo, Multi-Channel Stereo, Multi-in, Virtual, under Movie, then similar under Game. None of which sound even somewhat decent playing Call of Duty. With my old Denon avr 2803 I was able to set it to DTS, Dolby, or all of those. I'm using just an HDMI connection if that makes a difference. When I'm on the input for me cable box I have all those options such as Dolby... What am I missing here?
post #4397 of 7833
Do you have a newer PS3 slim, or the older "PHAT" version? If you have the slim, you can set the audio output on the PS3 to "Bitstream" instead of "Linear PCM" and you should then be able to access more surround modes on your AVR.
The older "PHAT" PS3s will not output multi-channel discrete audio (i.e. DTS-HD Master) when set to "Bitstream".
post #4398 of 7833
Wondering if folks could help me with an odd HDMI problem I am having with my AVR-3313ci
Here is my setup:
Sony Blu-Ray + ATV > AVR-3313ci > HDMI over Ethernet (Mon1) > Samsung UN65ES8000F.
I also have the following configured for audio return when watching built in apps:
Samsung > Optical Cable > AVR-3313ci (TV Audio - Opt1)
The TV Audio input works fine for say an hour or two, then I get audio dropping in and out. On investigation I discovered that at the same time as the audio drops in and out Mon1 is connecting and disconnecting in tandem (via status lights on the HDMI over Ethernet adapters). TV Audio is set to have no HDMI input.
If I unplug Mon1 from the AVR then the issue stops. If I connect another device to the HDMI over Ethernet adapter (e.g. Roku) then that is solid and works fine (seemingly eliminating the HDMIoE as an issue). But here's the further catch, if I then reconnect the AVR to the HDMI over Ethernet and switch to Blu-ray or ATV inputs, the 3313 WILL NOT output any video on Mon1 or 2.
When the AVR is in this state I have made sure conversion etc is off. The only way I have found to resolve the Mon1 output issue is to leave it overnight and in the morning it's just fine! confused.gif Could it be a component in the 3313 overheating after 1-2 hours?
post #4399 of 7833
Couple of questions for the 2113 or 2313 (I suspect the answers are probably the same for all the xx13 models)
1) Does anyone know what video latency is added by the HDMI switching / overlay functionality? While any result to the audio can clearly be addressed by the receiver, I'm wondering if it has an impact on games.
2) When doing 3D content (3d Bluray), what does the Denon UI look like? Or does it simply not appear while doing 3D content?
3) I was disappointed the 2113 only has 2 digital audio inputs (only 1 optical and one coax) because HDMI connectivity issues aren't as uncommon as one might hope... and when that occurs, you will need these inputs. I've heard that the Dennon has less compatibility issues than, say, Onyko ... but don't have any hard data to support this. Anyone have a gut feel regarding how often HDMI issues pop up? (BTW, I'm not blaming Denon or the source device or the sync device, just noting that it occurs).
4) And finally, anyone know of a traditional review of the Denon audio (7 channels under full load) somewhere? I've looked and haven't found anything that actually measures the loaded output and sound quality. There is a lot of talk about features, which is great, but not so much this area.
post #4400 of 7833
First off, as we were trying to explain to the other poster, don't confuse a different volume structure with a lack of power. 50% on the dial doesn't mean the same thing on every receiver. Denons are calibrated to a specific reference level and then digitally attenuate the volume by the decibel scale, which is logarithmic. That means a 10dB increase is 10 times more power. So 50% (e.g. 40 on the standard scale, with 80 being reference). is 10^4 or 10,000 times less power than reference level. It is totally normal to crank it up to near reference if you really want to rock out; typical home listening for a loud "movie night" experience would be 10-15dB below reference, or 65-70 on the standard scale. This doesn't mean the receiver is underpowered, it's just a different method of volume control.
Also note that engaging Dynamic Volume will drastically change the volume scale, both by making things easier to hear at lower volume but also by restricting the peak output at higher volumes. So if you want to rock out with Audyssey enabled, make sure Dyn Vol is off.
Second, if you do with to forego Audyssey, there IS a manual EQ you can adjust. You need to set the EQ setting (under Audio > Audyssey) to "Graphic EQ". After you set it as such, then a new "Graphic EQ" menu will appear in the Audio menu allowing you to adjust a nine-band graphic EQ. See pg 108 in your manual.
Finally, a lot of people who are used to un-EQ'd bass response think that there is a lack of bass after using Audyssey, because the room EQ has tamed some nasty peaks that you have grown used to. A lot of people like "hot" bass and are accustomed to these lumpy room modes which make things sound boomy, so give yourself some time to get used to the new smoothed bass response.
Unfortunately, not having a separate subwoofer does restrict what you can do in terms of tweaking this bass response. With a separate powered sub channel, you can independently bump it up a few dB if you want to run the bass a little hot after calibration, but with only two big main speakers you can't adjust that channel separately.
post #4401 of 7833
Hello,
I received my new Denon 2113 and hooked up my current dvd set speakers sothat i have some more time to get a set of decent speakers. All worked great on the first day. Now however, when i listen to the internet radio or stream music from my NAS directly to the denon using airplay i hardly get any sound from the speakers (at volume level 80 i get sound). Strange is that i get sound from the speakers at volume level 30 when i listen to audio with tv cable as a source or when i stream music to my mediaplayer to the denon.
It is as if the volume levels at the source are muted and the denon needs to boost these volume levels. Sound from cable and mediaplayer are fine though. A microprocessor reset didn't help.
Does anyone have an idea what to do?
post #4402 of 7833
This has come up several times in the Audyssey thread with ultra sensitive speakers like your KHorns. There are basically two routes you can take:
1. You can install an in-line signal attenuator, something like a 12dB attenuator will bring the KHorns into a better range for calibration.
2. You can do what you did and manually rebalance all the speaker levels. However, raising all the speaker levels will impact Dynamic EQ (although it doesn't affect the Audyssey EQ filters). Dynamic EQ is calibrated to adjust to what it assumes is reference level (master vol = 0 or 80 depending on which scale you use), but if you bump up all the speaker levels, then you will be listening at a lower volume, which means Dyn EQ will be boosting a little more than on a properly calibrated system.
What I would suggest you do is pick a 5dB increment, which will allow you to more easily match the Dyn EQ boost to the new reference level using the Reference Level Offset. For example, let's say you pull out your Rat Shack meter and find that all speakers read 73dB at the Audyssey set speaker levels (except possibly the KHorns which may have run out of room). So rebalance all the speakers at 78dB, exactly 5dB higher. You will probably end up with the KHorns still way negative, but at least not maxed out.
So after doing this, you will end up turning the volume down 5dB to achieve the same loudness. For example, if you listened to a movie at -20dB, you will now be at -25dB because all speakers are 5dB louder. To combat this, you simply bump the Dyn EQ offset by 5dB, which will reset Dyn EQ so that -5 is the new "reference".
Note that this offset is memorized by INPUT, so you will have to set it separately for each source. For non-film sources (cable box, music, etc) which you probably want at a 10dB offset otherwise, that means you will then bump the offset to 15dB.
post #4403 of 7833
Perfect, thanks BatPig!
I think I'll go with option 2. But, if I wanted to get an attenuator, where would I find such a thing?
post #4404 of 7833
Originally Posted by TM700user View Post
Hello,
Volume levels with Airplay are initially set by (and can be controlled by) whatever you are streaming with, i.e. your iPhone, iTunes, iPod, etc.
Not sure why the Internet Radio would act that way though.
post #4405 of 7833
I have the older version of the PS3 (PHAT). I checked and it's already set to Linear PCM, yet I have no options for DTS or DD.
post #4406 of 7833
So I ended up unticking all the PCM options and now it goes to Dolby Digital. Can I adjust the speaker levels on this input that won't effect those on another input (ie TV)?
post #4407 of 7833
Hello folks. Thank you for all the wonderful information contained in this forum. You all have made me into a very savvy and educated consumer.
I am currently debating purchasing either a used 4311ci or a new 3313ci. Price is about equal. I am looking at the high end units because of their preamp outs primarily.
I do listen to a lot of high quality flac sources, but a 'guilty pleasure' I find myself listening to often is XM radio. The over the air quality has really gone downhill lately and most channels sound atrocious. I typically listen to the streaming version as the quality is usually much better.
Obviously the 3313 has XM streaming and the 4311 does not (OTA is not an option for the 4311 due to the compression). For anyone who uses it, How is the streaming player on the 3313? Does it really sound at least as good as a pc playing with a digital input to the amp?
I must admit XM streaming is the only feature that is missing in the 4311 that I really miss.
Thanks in advance.
post #4408 of 7833
I too am an XM listener, though via an XM tuner that I have currently connected to my 1909's analog RCA (HDP) input. Are you saying that the compression/sound quality is worse listening via an XM tuner vs. listening online/streaming? If so, crap. I have recently considered dropping my three XM receiver subscriptions, to just listen via our iPhones in our cars, but on line has a much limited channel selection vs. from the tuners (which is a pisser). Especially several talk channels we enjoy.
I am curious of the comparision of sound quality/compression of Pandora vs. XM steamed and XM Tuner. Anyone familiar with these three in a sound quality comparison.
I would love to stop paying the exorbitant XM fees, but we have felt hooked. Maybe I can change my mind hearing others thoughts on this issue.
Thanks, Dave
post #4409 of 7833
Just so you know, what you were getting before was correct. MultiCH PCM input is higher quality than Dolby Digital, when you unchecked the PCM output it defaulted to the downrezzed Dolby Digital output.
You should redo the "Auto detect" for audio modes on your PS3 so it identifies that your receiver can accept multich PCM input.
The correct surround mode in this case would be "MULTI CH IN".
Why do you feel you need to adjust speaker levels? Can you explain more clearly what the issue is?
post #4410 of 7833
Originally Posted by jdsmoothie View Post
Try turning Dyn EQ and Dyn Vol both OFF as these features are likely the cause ... Dyn EQ will boost the bass/surround audio at lower volume levels.
Hey JD, I figured it out so I thought I'd post a quick follow-up in case you ever have someone asking you this same question. Turns out that my DVD player's software had a bug which caused an half second audio skip whenever the DVD crossed over into a new chapter/track. I think the 1613 always does a quick ramp-up of volume whenever it recieves a new audio signal which made the skips even more noticable. Updating my DVD player to the latest software fixed the problem altogether. As always, thanks again for all you help.
