I went to d/l the latest firmware for my 2113 because I see it fixes the Pandora login and the unit has been stuck on "Authenticating" for 2 hours now (after hitting the start upgrade menu option). Checking for an update times out too. I know networking is working because I can still use my phone to change volume/input/etc. I see from the early posts that we can do a network reset but I also see that doing so will essentially perform a factory reset on the device. Soooo...
1) Can anyone else successfully check for and install a firmware update, or is it just me?
2) If I do the recommended network reset, will I lose my audyssy settings?
3) anything I can try before doing the network reset?
