Originally Posted by 1956msg
Hi,
I saw your detailed post and hope you can help. I'm considering the 3312 or 3313 and want to verify that you can output 2 different HDMI in sources to Out 1 and Out 2. I.E. Blu Ray to Out 1 and Sat/Cab to out 2. Will it pass thru the video unchanged as well with no upscale or conversion. (HDMI in I mean)
Also will any models below this output 2 separate sources.
Hi,
The 3313 (and 4520) have 3 HDMI outputs. Two of them, on the main zone, will output the same thing. The third output (zone 2 on the 3313, Zone 4? on the 4520) can be independently set to any of your HDMI inputs. It is important to note that if you set both zones to the same input, the HDMI source will see the lowest common denominator in terms of audio and video capabilities. IE if your zone 2 is just connected to a 2D TV, you're only going to get stereo and 2D out on the main zone sa well, even if your source is capable of sending DTS-HD and 3D. The moment you switch zone 2 away, it should re-negotiate back to the best available.
I use this at home quite a bit.... I can be watching the game in my living room, while my girlfriend watches netflix in the bedroom, all on the same system.
