Guys, I'm having a bunch of problems calibrating with my 2113. I have a 5.1 mirage os2 with a 10" sub. I've run the audyssey setup several times and still don't have the bass right. The first few times I was getting very weak bass. I did some research and found out I had the sub in auto, it needed to be on. iPad the phase 180 degrees and the frequency low, both needed to be opposite. When I got it all right, the setup still told me the sub was about 18 ft away when it is actually about 12 ft away. Bass was still low. I went out and bought a sound meter and set the sub to about 75 db (it probably wasn't that close as I have no idea how to take the measurement). Do you sit in your normal spot or get right on the speaker when taking the reading? After running the calibration again, the sub level was -12 (gain set to 3/4) and the bass was way too loud. I forgot to mention, after getting the sub setting right the cal level was -3.5. Can someone point me in the right direction? Am I just being unreasonable about the bass?
post #5641 of 7945
2/16/13 at 7:21pm
