Originally Posted by jdsmoothie
1. Correct.
2. Yes to the first part, no to the second. Zone 2 is only analog connected devices, network sources, FM Tuner, and USB.
3. No. Audyssey only applies to the main zone speakers.
4. Using the front panel display can be difficult at times. Much better served using the Web Control feature (p. 89 OM) or smart phone app. The 1613 does not support the Web Control feature, although does support smart phone control.
5. See #2 above. This is the case for at least 98% of all AVRs on the market today. Among the few that are able to pass PCM 2.0 over optical/digital coax include the prior year 331XCI series with the exception of the current 3313CI; however the 3313CI is able to pass HDMI to a Zone 2 using a dedicated Zone2(HDMI) output.
For more info, refer to the Zone 2 section in post #3 of this thread ....
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100#user_M
1. Correct.
Thanks, jdsmoothie! That's very useful information.
i. I'm not completely clear on #4. So it sounds like the front panel could be used, but it is simply a PITA. Can the DLNA server be fully browsed and accessed via the smartphone app? That is, I could browse and choose music remotely with the smartphone app, all without the need for a TV plugged into the AVR?
ii. It is unfortunate that Zone 2 cannot be Audyssey-calibrated. In lue of this, do you know if the speakers of zone 2 can be equalized with the 9-band graphical EQ?
iii. If yes to ii., I may instead be able to, connect the PC to zone 2 with an analog interconnect, and stream FLAC to the more critical, calibrated zone 1. Do you know if in this configuration, the analog source could be routed to both zones? How about the DLNA streaming in both zones?
FYI, and this is a bit of a diversion, but part of the reason I'm so interested in the DLNA streaming is that I can't envision a cleaner way to get lossless media to the speakers. I believe the Denon DACs in the AVR will be better than anything else I can get in a reasonable price range, and there will be minimal accumulation of noise on the analog line, as it doesn't have to run very far and presumably they've done a good job shielding internally. In my head, I'm imagining the alternative--a Sonos or other network streaming device, doing the DA conversion and lossy, noise-accumulating RCA cables running into the back of the AVR--would result in a lesser quality output in the end. I also wonder if even using a digital input from another device (like a Sonos, or the PC) would likely result in reduced quality versus the internal network streaming, because the devices (or soundcards) usually resample the digital signal (rather than pass it on in its native format), which leads to quantization noise. But perhaps resampling is going to happen internally in the AVR anyway. Any thoughts on this??
