Originally Posted by kinggfx
Thanks - If that doesn't work do you think I can exchange it as best buy since I bought it less than a week ago?
Also going forward is there any way to prevent this (aside from not blowing any fuses..). I have everything plugged into a sturdy surge protector strip so I thought I was OK
I have my A/V equipment on a UPS battery back-up with voltage regulation. That should help give "cleaner" power and give some time to properly shut down the equipment in the case of a power outage or tripped circuit breaker.
Edited my post for correctness.
so maybe this could be the issue. I unfolded a metal hanger and stuck that in the bottom of the mic where the screw of a tripod would normally go, it held it straight as an arrow though, so it seemed fine.
