I just bought a refurbished AVR-1913. I hooked it up to the tv and went through the setup assistant procedure. I had no problem and hooked up my cable box and apple tv. Both worked. I turned everything off. When I went back to watch Netflix on the Apple TV, nothing worked. I fiddled around a bit, did a microprocessor reset, then did an HDMI HDCP reset as suggested here. It worked. I ran through the setup procedure again and watched Netflix for a while, then watched cable, then turned it off. Sure enough, when I turned it back on, I got nothing. Now when I say nothing I mean I was not even able to bring up the avr's gui. I decided to eliminate both the cable box and the Apple TV. I reset the microprocessor and did another HDMI HDCP reset. Basically, my only goal now is to display the avr's gui on the television (a Sony Bravia kdl46v5100). I was successful in doing this and I went through the speaker calibration again. I did not put either the cable box or the Apple TV back on the avr. I turned off the tv and the avr, then turned them on again in 5 minutes. No gui. I suspect I could bring it back after another reset, but that would hardly solve my problem. Any ideas? The tv is an older model and it predates arc.
post #5791 of 7921
2/25/13 at 3:19pm
so maybe this could be the issue. I unfolded a metal hanger and stuck that in the bottom of the mic where the screw of a tripod would normally go, it held it straight as an arrow though, so it seemed fine.
