Note that with regard to shorts I was intending to refer to the speaker cables, not the HDMI cables.
Originally Posted by Nuttygambler
Selden Ball: Help a little? NO! They help a lot... Yes the room is on a large loft area of the second floor with open ceiling and a large great room beside it to the lower level.
It is a large area, but I didn't think my old Pioneer was rated much higher... maybe 110 watts... and you could "ROCK THE HOUSE" with movies and dance music.
Using the calculators the amp "should" have enough power to "fill the room" to ear damaging levels with these front speakers.
1) First order of business is to get it to shutoff which won't be hard, and check out that light.
2)Then recheck my cabling... maybe there is a little short somewhere.
Good luck!My HDMI cables "should" all be from mono and high quality, but maybe in haste a cheapo got used in the line.
3) Then rerun the setup... I may have used Large for front speakers
4) Test it again...
5) Try to determine if the amp is just too small for the room or if it is faulty...
4) Test it again...
