As others have noted the sub distance is accurate because the measure is of acoustic delay, not physical distance. This is caused by the filters in the sub introducing some signal delay. Your BIC sub has a crossover bypass switch in it, if you set this to the "digital" position (i think that's what it's called on your sub) and rerun Audyssey you will get a shorter distance because the filter in the sub will be deactivated.
Esp. in the lower register.
