AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ
The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 273
post #8161 of 10468
This usually occurs when HDMI CEC is enabled on the TV (eg. Anynet+, BraviaSync, VieraLink, AquosLink, etc.).
post #8162 of 10468
And I know of no way to turn this off on my Samsung LN40B610A5F. I believe it can't be turned off on some TVs like mine. The duel volume control on screen is the norm for me and was present before and after the firmware update.
post #8163 of 10468
Here is a link of pg. 48 of your manual for some trouble shooting. You can play around with your settings to see if you can make the extra volume display go away. You may need to reprogram your Harmony after, or not.
Also in the GUI section on your avr menu there is a Volume control setting that will allow you to shift the volume display to the top or turn it off completely.
http://www.manualslib.com/manual/479303/Samsung-Ln40b610a5f.html?page=48
Edited by spager - 6/8/13 at 3:43pm
post #8164 of 10468
Thanks for finding this page. I don't think I am having any problem with Anynet+ being turned on. It doesn't bother me that there are two volume indicators on the screen at the same time. The person that was bothered by this was "parlyle".
Is there some reason that I should turn Anynet+ off?
post #8165 of 10468
Oops replied to wrong poster. If all is working fine for you then there is no reason to turn off Anynet+ to off.
post #8166 of 10468
Originally Posted by Unaverage View Post
So my Denon AVR-1613 receiver seems to have picked up a severe case of "staticitis" (hearing static while playing my music particularly). I have come to the conclusion that it is the receiver as I plugged in one of my high-end headphones into the front headphone jack and I heard the exact same static pops during the same time of my song which when played through my computer or anything else, I do not hear the static during that part.
Any way I can solve this problem at home? I'd rather not have to send it in. All help is appreciated.
Review post #5 of this thread and SAVE the config file to a PC and then reset the microprocessor to see if that will resolve your issue.
post #8167 of 10468
Originally Posted by chopin1397 View Post
I have the denon 1713 with an lg 6700 and directv. I am using arc so when I press the ‘off’ on the directv remote everything is off. To turn everything on, I have to first slide the switch on the remote to the av1 position, hit pwr. That turns the denon on. I then have to slide the remote switch to ‘tv’, turn on the power button and the set top box and the tv comes on. Then, the problem. The screen comes up on the tv normally. After about 5 seconds the screen goes blank. I have to press ‘cbl/sat’ on the denon remote to get the picture back. I use the hdmi control to ‘on’. I’ve tried just about every setting and it still does this. Frustrating.
The issue is caused by using ARC ....
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#user_E4
post #8168 of 10468
Is there a way to save/backup the settings on an AVR1713 using the web interface? The "normal" web interface at http://AVR-IP/MainZone/index.html appears to be working fine although quite slowly.
However, http://AVR-IP/SETUP/f_setup.asp which should provide access to a backup menu only comes up with the attached screenshot, regardless of browser and OS.
Haven't yet tried to reset the processor, since I wanted to backup the settings first smile.gif
Does the above work for you? Appreciate any help.
AVR1713.png 18k .png file
post #8169 of 10468
Try a different browser.
post #8170 of 10468
IP address/Setup_index.asp
post #8171 of 10468
Great, thanks!
post #8172 of 10468
I reset it both via the "soft reset" and then through resetting the microprocessor and I still have the exact same "static popping" noise which isnt too noticeable but for someone who wants to listen to quality music via Airplay playing at 320kbps, I can definitely notice it. I can also still hear the pops at the same part of a set of songs with my headphones plugged into the receiver.
What should I do now?
post #8173 of 10468
Try disconnecting all wires/connections to/from the AVR and reconnect.
post #8174 of 10468
I'm considering the 1913 but I'm curious about playing music over the network. I want people to be able to control what's playing through their iPhones from outside.
1. Does the phone need a Denon app to play music or can I just connect to wifi and fire up Pandora or a mp3 and have it play?
2. What happens if two people try playing something at the same time?
post #8175 of 10468
1. Well .. you need some kind of app ... either Denon remote app, 3rd party remote app, or for streaming from the phone ... Pandora, SiriusXM, Airplay, etc.
2. Did you see what happened in Ghostbusters when the streams were crossed? eek.gif
post #8176 of 10468
Originally Posted by gregavi View Post
Hi,
I'm helping a friend setup his 2313 for a "Zone 2" configuration. In his "Main Zone" he is running a 7.1 system. My question is, when using 7.1, do I need an external power amp for "Zone 2"? The OM is a little hard to understand, but after reading through it, I'm concluding that when running 5.1 in the "Main Zone", an outboard amp is not necessary, but when running 7.1, an external amp is needed. Is this correct?
Thanks in advance.
Yup. Correct on both counts.
post #8177 of 10468
I didn't think AirPlay was an app - just a feature of iOS. Is that not the case? I use a blackberry so I don't know much about iOS.
post #8178 of 10468
It's basically a system app in the iOS, at least an update. Click an icon on the music player and it streams to the stereo. I think it also works from a pc with itunes, but I haven't tried that yet.
Edited by CentralCoaster - 6/10/13 at 1:40am
post #8179 of 10468
I Need some help! Just picked up a new 1713 for $279! Loving it except I am having issues with the ipod input. The first 2 times I used it, it worked but was glitchy. It kept jumping back and forth between being able to be controlled through the ipod itself, and the TV only. Then it just stopped working all togeher. It just says NO CONNECTION now every time I try to use it. I tested 2 different cables that are both functional, so I know its not that.
Did I miss something in the settings? I looked but couldn't find anything. Shouldn't it just work?
I am thinking it might be defective.
Any advice on this would be great.
post #8180 of 10468
Does the USB port on AVR-3313 offer asynchronous mode?
post #8181 of 10468
I have my 1713 running Def. Tech. Promonitor 800's (L/R), a Procenter 1000, and a Prosub 800. I do not have rear speakers yet.
I have all speakers set to SMALL. Is this the right setting?
Also, What should I have my crossovers set at for this setup?
post #8182 of 10468
Yes.
Leave LPF for LFE at default setting of 120 Hz. I have my system crossover set at 110 Hz (KEF iQ30 front/iQ10 rear and Rythmik F12SE sub). Default is 80 Hz. but experiment with it to find best setting for your system.
post #8183 of 10468
Originally Posted by Iain- View Post
Yes.
post #8184 of 10468
1.Just to add to your other posters replies. All iPhones 3gs and higher as well as iPads, iPod touches and any iTunes computer or Laptop can stream wireless over your wi-fi network using Airplay. The Airplay icon will appear without having to add any app as it is incorporated in iTunes and on your apple devices. You just need to enter your wi-fi password to engage Airplay. Since you mentioned outside and if you plan to use separate speakers for zone 2 you could add an Apple Tv for around a hundred bucks and use it to stream different apple content from the main zone from an apple device or itunes to zone 2.
BTW check out pg.1 of this Forum if you haven't already and check out all the differences in models as you may want to consider the 2113ci over the 1913.
2. If you do not stop your apple device or iTunes before entering another activity it will continue to play but will jam the avr and force you to unplug it for a few minutes.
Edited by spager - 6/10/13 at 2:34pm
post #8185 of 10468
What did the AVR set the speaker crossovers to when you ran Audyssey? If < 80Hz then raise them to 80Hz, if > 80Hz then leave them as is. Review the Audyssey 101/FAQ Guide linked in my sig for additional help.
post #8186 of 10468
To what end? It supports audio only.
post #8187 of 10468
Has anyone figured out how these damn 3D glasses operate? I turn them on, they don't work. I reseat the battery multiple times before they work, then I turn them off (or back to 2D) and then even 10 minutes later I have to reseat the battery 10 times to get them to work again. Has anyone gotten a handle on how to operate them correctly?
post #8188 of 10468
disclaimer for sexual intellectual, NOT tuffluck: I do NOT own a 3313, but, I'm pretty sure it didn't come with 3D glasses...what BRAND/Model are they?
Edited by SanchoPanza - 6/10/13 at 3:20pm
post #8189 of 10468
You're posting in the Denon AVR-XX13 Owner's thread rather than one of the 3D video threads which would be more appropriate.
post #8190 of 10468
Predominantly for the potential of improvement in sound quality over bog-standard USB ports but also including, but not limited to the possible potential for:
  1. Upgrade to multi-channel FLAC file usage (ala, DBT-3313 recent firmware upgrade)
  2. Upgrade to .DFF format DSD file usage
