AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ
The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 312
post #9331 of 10468
so, what fixed it?
Originally Posted by drewba View Post
I'm having an issue with volume on DVDs played on a Sony BDP-S3100 Blu-ray player that's connected to an AVR-1913 via HDMI. Basically, DVDs have very low dialog levels when compared to Blu-ray disks played on the same player. DirecTV seems to be working fine as well.
Audyssey calibration was performed and dynamic volume is set to Medium.
Any ideas?
post #9332 of 10468
Originally Posted by ynos6600 View Post
I have problems with Airplay and AVR2113. Connection seems to drop every 1-2 minutes, music stops for 3 seconds and then resumes. I noticed this after upgrading to new firmware.
Wifi connection shouldnt be a problem. I have 100/100Mb line and Netgear 3500l router, which is capable to stream FULL HD to my Boxee Box.
Any ideas?
You're using an iPhone I presume? iPhone wifi is garbage, I've had problems with my 3GS, 4, and now my 5. They just don't seem to play nice with routers (I'll bet they work great with AirPorts) and the connection will randomly drop regardless of what you're doing with it.
post #9333 of 10468
Hi - I just want to confirm what I think I read and am experiencing.
I would like to attach a Chromcast stick to my Dennon 3313. I can cast Google Play Music from my phone to zone 1` but not to zone 2. I think that's because Zone 2 doesn't support audio from HDMI devices. Am I understanding that correctly?
Since I have all my music in the Google Cloud (in addition to local FLAC's), I'm trying to figure out how to get it to my deck via zone 2 on my Denon.
post #9334 of 10468
Correct, HDMI audio cannot go to Zone 2 on your receiver. The newer models (e.g. X4000) can do it though.
post #9335 of 10468
Originally Posted by JasonColeman View Post
Finally getting around to posting an issue I've been having for a while with my 3313. When turning on the entire system via our Harmony One (let's say, to watch a movie via PS3), there is no audio at all from the AVR. I can cycle the 3313 off/on and that usually fixes the problem, but it's just a pain in the ass that shouldn't be. Any suggestions or solutions?
Jason
Try changing up the order the devices are powered on ... first sequence that is generally recommended and works most often ... TV, wait a few seconds, AVR, wait a few seconds, and the finally the source (PS3).
post #9336 of 10468
Originally Posted by smeg36 View Post
So I discovered a problem with my 2113CI today. I was troubleshooting a video problem I was having with my Tivo connected over component and horizontal lines moving up the screen on dark scenes. It turned out to be a grounding problem that was fixed by running the coaxial through my APC H10 power conditioner. But in the process I disconnected and reconnected the component cables several times on the 2113CI. I recall when I first plugged the component cables in the picture looked a little off, but that was fixed by wiggling the cables around a bit. Today, however, the problem appears to be compounded, and the picture keeps dropping out when I connect the cables. Jiggling them around can get it back, but usually it's colors are off.
I tried using different cables with no success. I plugged it directly in to my tv (where it is connected presently), and the picture is perfect with no issues. Clearly, the receiver (which is a refurb, I think I know what the original problem was now) is having component problems. I should still be under warranty as Denon changed it to 1 year from 90 days, but really can't go without my receiver for the length it would take to repair it. Is taking it to my closest repair center (which is 45 minutes way), or mailing it to Denon, and being receiverless for the duration of the repairs my only options? I really don't want to go without a receiver, and love the sound I get out of the 2113CI.
Have you tried doing a soft reset (unplug for 10 min) or a hard reset (micro/network reset as noted in post #5 of this thread)? Otherwise, you would need to call the local repair facility to ask them to provide an estimate of turn around time. Generally, units shipped to the factory repair center, PanurgyOEM are returned within 1-2 weeks (often much quicker than the local repair centers).
post #9337 of 10468
Try connecting the Chromecast stick to one of the Monoprice branded splitters/converters such as the one below which should allow you to pass the HDMI audio to Zone 1 and the analog audio to Zone 2. smile.gif
http://www.monoprice.com/products/product.asp?seq=1&format=2&p_id=8145&CAWELAID=1329456220&catargetid=320013720000010710&cadevice=c&cagpspn=pla&gclid=CKjihOvS57kCFVNo7AodcnUAdA
post #9338 of 10468
I haven't done the resets as it seemed like a hardware issue, and I didn't want to redo the Audyssey setup, but I'll definitely try it tomorrow. The service center was a 7-10 day turnaround. It'd be difficult to go that long without a receiver.
post #9339 of 10468
If you are considering repair, you might as well try the reset first. smile.gif
post #9340 of 10468
Agreed. I think I'd live with the issue instead of live without the receiver though. It works, the component cables need to be plugged in just right to work though. If it got worse in the next 8 months I could always opt for repair then (thank goodness Denon upped the refurb warranty to a year).
post #9341 of 10468
If you purchased with a credit card, check with your card issuer as they may add a 2nd year of warranty for FREE (AMEX will for sure as will some MC/Visa too). smile.gif
post #9342 of 10468
Forgot about that, they do. I remember checking on it before I bought it. Thanks for the reminder.
post #9343 of 10468
For some reason, when I use Spotify / Pandora / AirPlay on my 1913 and 2113, I am not able to select PLII Music anymore, it defaults to PLII Cinema and I can change it off this setting using any remote. Can someone show me the magic way of doing this? (also - does it even matter? Are PLII Cinema and PLIIX Music essentially the same? I don't think they are, but I don't know for sure).
post #9344 of 10468
No they aren't the same. Cinema is going to be more center focused.
What happens when you push and hold down the Music button on the remote? What options appear on the tv screen?
post #9345 of 10468
I use Mac Book Pro. Until few days ago everything worked OK. Now it is loosing streaming signal. :S
I tried streaming music on another device (Boxee Box) and everything works ok. So problem must be with Denon Receiver.
post #9346 of 10468
Any chance you are using a wifi extender of any kind?
post #9347 of 10468
No. Denon is conected directly to router. Something else i noticed. Sometimes during airplay playback i see (i dont know how to say) disturbance on image on TV, like HDMI cable would be defective. Colour turns pink, image jumps and everything goes back to normal. But this doesnt happen when i watch or listen other sources. And HDMI cable shouldnt influence AIrplay playback.
post #9348 of 10468
Any ideas?
Try resetting the router as well as doing a soft reset (unplug 10 minutes) of the AVR.
post #9349 of 10468
That certainly is a sweeping statement that I would challenge. I've had no problem using Airplay with my iPhone 4s and 5s using a router...
post #9350 of 10468
+12.
James
post #9351 of 10468
I said my experience. Different routers, different providers, I have ALWAYS had wifi drop outs with iPhones.
post #9352 of 10468
With Chromecast not an option for Zone 2.
I'm not trying to get AirPlay working. It works fine on zone 1 but how do I get AirPlay on Zone 2?
Additional back ground - I can play other things, like Internet Radio on Zone 2. I just don't know how to select AirPlay on Zone 2
post #9353 of 10468
You can't initiate airplay directly to zone 2. First fire up airplay in main zone and then select "network" as the zone 2 source and you should hear the airplay audio. At that point you can change main zone back to another source if you so desire.
post #9354 of 10468
Did you try the HDMI converter I suggested in my earlier post?
post #9355 of 10468
Hi - no, I appreciate the advice but I'm not interested pursing the Chromecast solution anymore, especially if it means buying a $60 converter to make a $35 device work biggrin.gif
So I'm trying something that is supposed to work. My understanding is I can run AirPlan on Zone 2. I just can't find any coherent instructions regarding how.
post #9356 of 10468
What about my post above?? I'd like to think that was pretty coherent smile.gif
post #9357 of 10468
Thanks - I got it working. I suspect my problem may have been at partially due to some flaky interaction using the Denon Android app and maybe even the Retune app to control iTunes
If, from the receiver, If I get AirPlay running on Zone 1, then switch Zone 2 source to Network, I get sound.
It works fine unless I try to do anything with the Denon or AVR-Remote app. Both seem really flaky. I guess I need to keep it simple and set it up from the receiver and just use ReTune to control the songs.
post #9358 of 10468
Hi I have a 1913 and recently encountered an issue where "Direct" mode is automatically being selected by the receiver. It previously was all setup with Audyssey and sounding just fine, automatically switching between Dolby and other sound processing signals as it seemed fit; then just the other day it has switched to Direct mode (while watching satellite tv), and no matter what I do, I can't seem to shake it out of that mode.  Is there a known reason why this is happening?
Thanks in advance - apologies for the noob question if its been asked and answered, I couldn't find it.
-Nick
post #9359 of 10468
Are you using a Quick Select to select the SAT audio? If yes, then reselect the mode desired and resave the Quick Select by pressing/holding the Quick Select button on the front panel.
post #9360 of 10468
Hi, the HDMI input for CBL/SAT doesn't seem to work right (always drops audio), but the DVD input does and is what I have my cable plugged into. Is there a way to default the AVR to automatically choose this option when I turn my TV on/off instead of TV audio? Thanks.
