Newbie first time projector owner.. I just took my Panasonic PT-AR100 out of the box to check the ideal ceiling extension column height. I set the menu to project from front/ceiling.
All of the diagrams in the manual (and everywhere else I've seen) show the image lined up with the top of the screen and top of the lens when it is in ceiling mode.
However when I have the optical shift lever in the center, the image is not lined up like this. Instead the image is lined up so that the projector would have to be vertically dropped down quite far, vertically centered with the screen.
I am trying to avoid moving the optical shift lever down so I don't have to use keystone correction.
Am I missing something obvious? Some other setting? Shouldn't the image line up so the lens is at the top of the screen image when it is in ceiling mode, and the optical shift lever is in the center?
