AVS › AVS Forum › Audio › DIY Speakers and Subs › Removing Fasteners after glue has set?
post #1 of 3
Having just built a new sub box, i am not done finishing it totally. I would like to do a 1/4-1/2 fillet on the edges to round them over. However, i used 2in drywall screws in building this so i didn't have to drag the build out with clamping all the time. I used pl premium and the wood is the EFS mdf looking stuff.
Would i be able to pull the screws and plug the holes with filler so i would be able to router the edges? And still maintain structural integrity?
post #2 of 3
I haven't done it personally, but I've seen a number of experienced builders at the BFM forum that either pull the screws and fill after the PL has dried, or use brad nails instead of screws.
post #3 of 3
Yes, the screws just hold it together until the adhesive cures.
