AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Does optical audio support DD+
post #1 of 7
Just wanted to know whether or not optical audio supports DD+?
post #2 of 7
It supports Dolby digital 5.1
post #3 of 7
DD Plus is supported by HDMI 1.3 and higher.
post #4 of 7
I know it supports DD. I asked about DD+
post #5 of 7
Please go to the DD Plus link I had in my post above.
post #6 of 7
The issue is not truly one of "support." TOSLINK optical has the bandwidth to carry two channels of 24 bit 96 kHz audio (~4.5 Mbps), so it could carry most Dolby Digital Plus bit streams. But Dolby Digital Plus does not allow S/PDIF output, only HDMI 1.3 output.
AJ
post #7 of 7
How will the avr decode the netflix stream of dd+ when connected via toslink? In dd 5.1? Would I even get audio? Thanks guys!
