AVS › AVS Forum › A/V Control & Automation › Remote Control Area › URC MX-880 and Popcorn hour 200 help
post #1 of 6
I have the MX-880 remote but seem it can not learn the code from PCH 200 , anyone can help me with this, or anyone have a hex code for this please share
thank you
post #2 of 6
If you are using CCP to program the 880 you will find the codes for the Popcorn hour under AUX - SYABAS - Popcornhour C-200.
Also, just to make sure you do have the IR kit for the C-200 correct? The OEM remote is RF.
post #3 of 6
I know this is pretty old, but I am also trying to program an MX800 for a old Popcorn Hour with CCP.
I just don't see SYABAS as a brand under AUX (or anything else for that matter). CCP is fully updated.
Any other ideas?
post #4 of 6
You can not use ccp to program mx-800 remote.
post #5 of 6
Any other ideas?
Assuming you meant MX-880 then just learn the codes from the PH remote into CCP.
post #6 of 6
As Edmund has said you cannot program an MX-800 with CCP. If you made a typo and are using a MX-880 the codes are definitely there. Make sure you are looking under the IR Database and not Serial or IP.
  Back to Forum: Remote Control Area
