AVS › AVS Forum › Audio › DIY Speakers and Subs › DVC385 Vented Sub
DVC385 Vented Sub
post #1 of 5
Somehow find myself addicted to WinISD. I don't know how many hours I have spent playing around in there.
So.. the DVC385 is on sale at PE..
I'm gonna need it for the F-20, but I thought it might be fun to design something myself just for kicks.
Can you guys see if I have done this correctly and give me your thoughts? Keep in mind this is my first try, thanks!
Attachment 245916
Attachment 245917
Attachment 245918
post #2 of 5
What are you using for power? It's always best to try and model with whatever high pass filter you will have in use. I think you're good otherwise.
post #3 of 5
Thanks, Jay. I'm not sure about power, but I was thinking the NU1000DSP might would work well. It would provide 430w at 8 ohms bridged.
I didn't realize the highpass would effect the output. What should I use to determine the highpass? Just somewhere above the point where the excursion exceeds xmax?
Thanks again,
Tim
post #4 of 5
Thanks again,
Tim
The DVC is dual 8ohm, so you would have either a 4ohm or 16ohm load from it. The RMS power handling is only 350 watts, so be careful if you have things cranked for extended periods with a high power amp. I think the lowest HPF you can set on the NU DSP amps is 20hz? The goal with a HPF is to keep cone excursion below tune in check, and you also want to see if your air velocity will drop a bit, 17ms is what you want to shoot for.
The Bash 300 watt and SA250 amps are good matches for the DVC. They booth have HPF's at about 18hz. A single channel from the NU1000 should also work well.
post #5 of 5
Ok, cool. The plan is to run a pair of F-20s if I ever get the theater done, so I had originally thought to go that route. The bash at 18Hz would be a better choice, I think.
Specs say the iNuke will do 320w at 4 ohms, which is a nice fit. WinISD says over 109db @ 20hz with the high pass at 20Hz.
Specs for the iNuke says response is from 20Hz, but I can't seem to find out if you can actually set the high pass lower than 20Hz (and if it will actually play that low).
Appreciate all your help. I realize these are some basic questions.
Tim
