I would like to know more about black levels.
Is the 7.5 IRE spec actually part of the NTSC signal on the source DVD/VHS/LD or is the 7.5 IRE added to the NTSC signal by the device that is outputing the signal, in this case a DVD/VHS/LD player?
If i had a PAL player that can play NTSC tape/disc at the original 3.58 spec (not conversion to 4.43) will this output the NTSC singal with 7.5 IRE or not because my player is PAL? In the latter case, would it mean that although playing it as 3.58 it wont be outputing the NTSC video with the correct black level?
If its the playing device that 'adds' the 7.5IRE to the NTSC signal, does that mean i would better off to use a native NTSC device that 'adds' the 7.5 IRE so that the black level is right if my PAL device only plays NTSC 3.58 but not with the correct black level?
I could not even say if its only DVD affected by this or VHS too? or if if the 7.5IRE is added by the machine or is present on the disc/tape.
Now I am really in the dark/light/dark about it.
