where to plugin a sys. fan?
My new PC did'nt come w/ a sys. fan w/ the addition of my new TV tuner and soon to be extra HDD I'm antisapating the need for a sys. fan
so where do I plug it in?
this image there's a 6 pin plug that comes from the PSU it is simiarl to the CPUs fan plug.
By stevethebrain at 2012-05-09
this image appears to be a 6 pin connecter
here's a old fan I have it only has 3 pins
current temps w/ couple hours of computing
CPU-21
sys.temp 37C/98 F
PCH temp 59
after 5 hours of continuos recording
CPU 29
sys.temp 44c/111F
PCHtemp 59
both reading are prior to new TV tuner card will check any changes later today.
I don't see anything labled on this MOBO. are there documents identifing each connection?
Thanks STB
CPU-21
sys.temp 37C/98 F
PCH temp 59
CPU 29
sys.temp 44c/111F
PCHtemp 59
Thanks STB
