I didn't find a thread specifically to this new line Canon just came out with and so i decided to start one . I have had mine now for almost 2 weeks and i love it !! I had the R300 to start with but i wanted better with better low light sensitivity . The M50 definitely has that ! The M50 has a 8-gig built-in memory with one card slot . I presently have a 16-gig SDHX card so that gives me a total of 24-gig. You have to choose where your recordings go to , either the Built-in or Card . I use the Built-in at the moment but i like to transfer to the card and just put the card in my computer and download without having to open any other software if i choose to . It will record in AVCHD or MP4 which is really convienant . It only has 10x optical zoom but in Manual mode you can choose 40x or 200x zoom . In Auto only the 10x optical is available . I really like the Auto-Close lens door and i have a 43mm HOYA UV filter coming in the mail . The touch screen is really easy to use once you know how to get around for settings and playbacks of picts and movies are really neat . You have 3 different built-in music sounds you can use to record with or add your own during editing of your film . Oh BTW as far as the pictures i've only taken a few and they were great looking . Battery life is fairly good for the M50 with the Canon factory battery . Full charge can get 2-3 hours of recording depending your settings and what format you record in and whether or not you add the on-board music . it comes with Wi-Fi built-in for uploading to your computer or the web or to a TV capable of Wi-Fi . I choose not to use it for security reasons . I've read where alot have had trouble tho with the settings of making connections but since i'm not using mine i can not verify that . I do know tho that what MP4 movies i have taken look great as well as the AVCHD movies which shoot at 1920x1080 with 2.07 megapixels which is all you need for HDTV . And one last thing at the moment is it has a 1/3-inch HD CMOS PRO, RGB Primary Color Filter sensor which is larger than most the other line below the M5 series . For right now til i get to know my camera better this is all i can input but here is a couple youtube videos i have taken so far . One inside and one outside .
http://www.youtube.com/watch?v=uqv8nP06uSw
http://www.youtube.com/watch?v=NgzaP...feature=relmfu
