AVS › AVS Forum › Video Components › Home Theater Computers › Any recent OrigenAE M10 builds
post #1 of 13
Just wondering if anyone has recently (even within the last year) built their HTPC with the OrigenAE M10.
I am looking to do so soon, but I can barely find any build that are from 2010!
The computeraudiophile build used the M10, but they didn't use the front display, which I intend to do.
Anyway, I am in the early planning stages and was just hoping to poach some ideas. I have been reviewing Assassin's guides but the motherboard in his high-end mini-itx system doesn't seem to be available anymore (or at least in Canada).
I realize this is a pretty vague post, but truly any links / thoughts / suggestions are welcome.
post #2 of 13
I've done a few builds recently with the similar Iwill HT100. There's a few posts floating around here in the mini-ITX case thread:
http://www.avsforum.com/avs-vb/showt...8#post21902288
Some blog entries:
http://outsidethestb.blogspot.com/20...s-arrived.html
http://outsidethestb.blogspot.com/20...th-35-hdd.html
post #3 of 13
Thanks! I appreciate the links.
Do you know if the two cases are similar enough that two 2.5" drives are are possible in the M10 if I have the ODD as well?
post #4 of 13
Short answer: yes
Long answer: Internally, the HT100 is basically the same as the m10 with the exception that the HT100's under-ODD mount allows you to rotate the SSD/HDD 90-degrees (if desired) so it doesn't interfere with the CPU HSF. I was able to install a 2.5" SSD in the side location and a 3.5" HDD turned 90-degrees underneath the ODD with the Gelid Slim Silence i-Plus installed. A 2.5" under the ODD doesn't interfere at all and was workable with a Silverstone NT07-1156. No idea about the stock cooler however.
The biggest difference between the m10 and the HT100 is the LCD/VFD. The HT100 doesn't come with one and fitting one is a homegrown solution. The Soundgraph VFD can be fitted it just takes a little work. I've been working with an LCD kit from LCDModKit.com to find an inexpensive solution. I know another guy who fit the Soundgraph LCD/VFD/IR kit with a little modding of the kit. As for IR receiver/remote, the HT100 is available with one (it's separate from the LCD/VFD module) and it's capable of turning the PC on from off.
post #5 of 13
Thanks again. I am really impressed with the knowledge on this forum and the willingness to share. I am sure I will need it in the future.
post #6 of 13
Hi there. I think I'm in the same boat as you are. I am currently in the process of trying to build a parts list around the Origen AE M10 case.
Here's what I have so far:
Case: Origen AE M10 (with VFD 210 for Linux compatibility)
http://www.shop.perfecthometheater.com/HTPC-aluminum-chassis-M10-VFD310-right-button-Black-HTPC-M10-VFD310-rb-B.htm?productId=349
Motherboard: ZOTAC ION-ITX S Series [IONITX-S-E]
http://www.zotacusa.com/products/motherboards/ion/zotac-ion-itx-s-series-ionitx-s-e.html
RAM: Kingston 2GB 204-Pin DDR3 SO-DIMM Unbuffered DDR3 800 System Specific Memory Model KVR800D3S8S6/2G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820139220
Blu-ray Disk: Sony Optiarc Black Slim Internal 12.7mm Slot Blu-ray Combo Model BC-5650H-01
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118070
SSD: Kingston HyperX 3K SH103S3B/120G 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820239049
My plan is to run a Linux-based XBMC install on this device. I'm primarily interested in streaming video from a server on my home LAN.
Anyway, I'm still in the planning stage, and cannot confirm whether or not the parts list above will work.
Feedback is welcome.
post #7 of 13
Those will all fit in the m10. What are you planning to use for the O/S and/or storage? SSD? HDD?
post #8 of 13
I am planning to either use OpenElec or Ubuntu for my O/S to host XBMC. Since I plan on using a separate server for my video content (DVD/BD rips), I figured that I could get away with just using an SSD drive as my storage unit.
post #9 of 13
That's ideal then. You can install the SSD in the side bay and not worry about anything under the ODD tray.
post #10 of 13
We were making a production run off of it but we are not now. I wasted some money on some custom rackshelves that I'll probably never sell now too since we are using a different chassis for our player frown.gif However, photos of the prototype M10 (and one of the shelves I'm stuck with):
post #11 of 13
What made you decide not to use the m10?
post #12 of 13
Nothing against this chassis. I wanted a 2U format, I didn't need the front screen, and I really needed a flex PSU setup so I could go to 300W. The 150w with even with the GT430 underclocked a little and the i-2300t version cpu was still pushing it to much.
post #13 of 13
Cool, thanks for the info. I was wondering if there was some defect or blocking issue you ran into.
These guys make some nice compact rackmount chassis: http://www.istarusa.com/istarusa/productlanding.php?division=istarusa&cat=Compact Rackmount Chassis
