Originally Posted by AsthmaticZero
I've been playing around with more picture calibration settings, and I thought I'd share. I've now tried (in order) the THX Optimizer (found on the Terminator 2: Judgment Day - Skynet Edition Blu-ray), the Avia calibration DVD, CNET's official review calibration settings (found here), and the AVS HD 709 calibration patterns (obtained here).
THX
Picture Mode: Cinema
Backlight: Min
Picture: Max
Brightness: 32
Color: 55
Hue: 0
Sharpness: Min
Color Temp: Warm 2
Noise Reduction: Off
MPEG Noise Reduction: Off
Motionflow: Off
CineMotion: Off
Avia
Backlight: Min
Picture: Max
Brightness: 45
Color: 51
Hue: G1
Sharpness: Min
Color Temp: Warm 2
Motionflow: Off
CineMotion: Off
CNET
Picture Mode: Custom
Backlight: 9
Picture: 97
Brightness: 51
Color: 50
Hue: 0
Sharpness: Min
Color Temp: Warm 2
Motionflow: Off
CineMotion: Auto 1
Advanced Contrast Enhancer: Off
Black Corrector: Off
Gamma: 0
Clear White: Off
Live Color: Off
LED Motion Mode: Off
White Balance: R-Gain (-5), G-Gain (0), B-Gain (-5), R-Bias (-2), G-Bias (+2), B-Bias (+3)
AVS HD
Backlight: Min
Picture: Max
Brightness: 50
Color: 52
Hue: G2
Sharpness: Min
Color Temp: Warm 2
Motionflow: Off
CineMotion: Off
You'll notice that the only wildly different one is CNET's, and even then, Picture and Color are almost identical across the board. I'd say that's a good sign that I'm on the right track. When calibrating by eye with a BD, DVD or test pattern, all of the info I found said to start with the Cinema setting, which I agree works best. CNET chose to use the Custom setting, which allows you access to the Advanced Options, of which they only changed the white balance. I think putting it on Cinema and leaning the Hue setting toward G a bit achieves pretty much the same effect.
I actually thought that CNET's settings were too bright, and they made my TV look washed out. I felt the AVS HD test patterns were a better-for-LED/LCD version of what the Avia disc includes, and the settings reflect that. The THX settings looked off to me. In every instance, I turned off all of the "noise reduction" and "motion" settings.
In the end, I decided that the settings I got with the AVS HD test patterns look the best in my viewing room. I watch in mostly darkness, save for the stove light in the kitchen in the next room, which supplies a tiny bit of light. If anyone has any comments on this or anything to add that might help me improve my picture even further, please let me know!
THX
Backlight: Min
Picture: Max
Brightness: 32
Color: 55
Hue: 0
Sharpness: Min
Color Temp: Warm 2
Motionflow: Off
CineMotion: Off
Avia
Backlight: Min
Picture: Max
Brightness: 45
Color: 51
Hue: G1
Sharpness: Min
Color Temp: Warm 2
Motionflow: Off
CineMotion: Off
CNET
Backlight: 9
Picture: 97
Brightness: 51
Color: 50
Hue: 0
Sharpness: Min
Color Temp: Warm 2
Motionflow: Off
CineMotion: Auto 1
Gamma: 0
Clear White: Off
Live Color: Off
AVS HD
Backlight: Min
Picture: Max
Brightness: 50
Color: 52
Hue: G2
Sharpness: Min
Color Temp: Warm 2
Motionflow: Off
CineMotion: Off
I really appreciate you posting these! I'll play around with them and let you know my thoughts once my EX645 gets here.
