AVS › AVS Forum › Audio › Home Theater In A Box › Any In-Wall / In-Ceiling Speaker Home Theaters in a Box systems?
post #1 of 2
Hi! I'm hoping you can help with an objective opinion. First off, I'm not an audiophile. Just looking for good sound for my home theater project.
I'm doing a new home theater (converting a standalone single car garage and the room will measure 14Wx16Lx11H)
I was thinking of getting a Pioneer 7.2 AV tuner to support my 3D projector (either the panasonic7000, optomaHD33, or Epson5015).
I'm struggling with finding the right speaker set-up because I'm not much of an audio guy.
I also found what looks like it is perfect, but has historically had dubious reviews - New Acoustic Audio. They have a product that you can find at thedeepdiscount dot com site and if you search for HD-728 and then click on the HD 15" sub option for $578, you'll see their speaker package. It's the only 7.2 in wall / in ceiling speaker package that I've been able to find without having to either hire a professional home theater shop or venture off into the dark corners of the audio universe to figure out how to piece together a solution.
Does anyone have any thoughts on viable solutions?
Ajay
post #2 of 2
Whats your budget? Triad makes great in wall speakers. So does Atlantic tech
  Back to Forum: Home Theater In A Box
