Originally Posted by
Apples555
Wow, lots of hate flying around.
Oh, no: no hate. Don't mistake passion for gear as hate: I don't think anyone has been negative toward you? Just trying to relate how we feel about the various solutions we've tried to your question. Everyone has a slightly different priority, so not all solutions will interest you, but thats what makes a forum useful.
I think I need to reiterate my point, as it seems to have gotten lost amongst all the confusion. I'm not looking for a VCR that removes the MV. I just need a VCR that will pass the MV-infected signal to the TV through RF so I can, you know, watch it.
Bingo: this is a confusing point to some of *us*, which may be why you feel we got off on the wrong foot. For instance, I've had more VCRs than I can remember, Beta and VHS, since 1981- and aside from the old Betas I have *never* encountered a VCR that would "pass thru" MV video to a TV without showing the tell tale flashing and distortions, UNLESS that VCR was completely blind to MV and would also record it without those symptoms.
This is why I responded with surprise to Super Eye's post about his JVCs: I misunderstood both yours and his definition of "MV resistance." I really am truly amazed to hear there were some VCRs that would cleanly pass thru the playback of MV video from another VCR or DVD player thru their line inputs to a TV, while still being unable to make a clean recording. It seems counterintuitive, since with 99 out of 100 vcrs the MV issue kills
both passthru and recording functionality (because the outputs show the effect of AGC tampering). Other than the "GoVideo" dual dubbing VCRs, the only VHS models I personally tried that cleaned MV were the very first JVC "HQ" decks and an old Minolta/Hitachi (but they were
totally blind to MV and would also make good dubs of MV tapes).
I prefer a VCR because I'd like to be able to watch my VHS tapes as well, without having an extra box in the chain.
This is understandable, but the VHS VCRs with the oddball MV response you're looking for are all pretty old, some are pretty scarce, and you really don't want to make an old second-hand VCR your primary VCR because it can act up unexpectedly and ruin your tapes. While its annoying to have the little RF modulator box, its a lot safer. You can buy a little two way video switchbox to connect both your DVD player and your current VCR into the RF modulator, both pieces are no bigger than a cigarette pack and cost maybe $35 total. Having the separate modulator means you're also not dependent on one single oddball old VCR for the function: it can be reconnected to any VCR or DVD player you buy later.
Super Eye
No, no, no, no - my newer model JVC decks are NOT immune to MV, I did not say they are. I said they pass-thou a signal all right as long as not in record mode.
jjeff
Yes I think the topic took a different direction when we started talking about which VCRs would
record MV'd tapes. AFA using a VCR strictly as a RF modulator of a MV'd source, it's my belief that all older(pre 2000) would do that but of course very few would actually record a MV'd source without problems.
To jjeff and Super Eye, yes, I was confused and didn't realize there was a third in-between MV VCR response of "pass-thru" along with "immune" or "not immune."
Super Eye
I think my funny accent through off the bear.
Naw, I'm a big fan of Canadians and usually understand them: SCTV, Kids In The Hall, all those tarty historical melodramas you produce for Showtime...
Apples555
...You know, I might just use a Beta machine as a modulator. My GW has two; A huge SL-5400 and a slimmer SL-25. Does anyone know how these react to MV?
The SL-5400 would work to filter MV on passthru, I had one and it was immune to MV altogether if I remember correctly. The SL-25 may or may not be good for passthru: at some point the front load Betas became vulnerable to MV. The SL-25 is circa 1984, so perhaps old enough to be immune: you could try both. However, either weighs a TON compared to modern VCRs and unless you have lots of Beta tapes its kind of pointless to have the big heavy hot-running Betamax taking up space on your shelf and eating as much electricity as a 150 watt bulb in standby mode.
I get that you're REALLY averse to the separate modulator, we all have certain bits of gear we just don't like for some reason, but its by far the easiest way to go and a sure bet to work as you want. Keep it in mind if you fail to turn up one of the "MV passthru" VHS decks in decent condition.
