AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNxxES7500 thread
Official Samsung UNxxES7500 thread - Page 8
post #211 of 368
Originally Posted by digimat View Post
Have you never heard of a massage? You must live in a lonely part of town...
Seriously though, it's just what it sounds like, grab one of those felt cleaners and rub your screen.
post #212 of 368
Originally Posted by morpheus305 View Post
What do you mean by massage the screen? What exactly do you do? Never heard of this.
Here brother...have fun reading and massaging your screen..the least I could do..
http://www.ehow.com/how_6516595_fix-spots-lcd-tv-screens.html
post #213 of 368
Thanks endeaveroux for your response. I realize that I should not complain if I use those smooth and standard settings. Originally reading these forums, someone mentioned that the syncplus app checkbox needs to be unchecked as it was causing picture problems. I found that little tidbit of info and tried that, but I was still noticing these little skips and flutters of the image in these automotion settings even after unchecking that box. I wanted to make sure my tv wasn't bad. I guess I was just wanting perfection after paying big bucks for this wonderful tv.
post #214 of 368
nothing is ever perfect...but this tv is very close to it....i love it...im glad theres an option to adjust automotion plus as you see fit...
some manufacturers dont give you the option to turn it off....
post #215 of 368
Originally Posted by rckrz6 View Post
Check balance setting on receiver and tv?
Thankfully, it turns out that the adapter cable (3.5mm to RCA) that came with the TV was bad. Bought a new one at Target and everything is ok.
post #216 of 368
hy am new to this forum...right now am in the dilemma of Choosing between two Model ES7100 And ES7500 i Will be getting the 46inch Model.....through Extensive Search and Research am Able to get these Differences between the Two model i have Seen the Comparison Char by Samsung between these Two Model Which Doesnt Actually tell u the True Difference
from Different Forum i able to get these Difference
3D Glasses are Different 7500 One got Better Glasses 7100 got Cheap Glasses....
Sound Quality Difference 7500 got DNSE while 7100 got SRS HD whihc is lower than DNSE
Voice and Gesture and Control and Camera Every one knows That
3d Sound in 7500 while in 7100 it not ...i dont know exactly abt this
2 Remotes conventional and the SMart one
Increased CMR Rate of 840 and Mircro Dimming pro in 7500 while in 7100 they are at std levels
i would like to know if any 1 know other Differences between these two i am leaning more toward 7500 because of the additional Features where i i live it $250 More than 7100
Can Any one Confirm About the PQ of both the TVs and the 3d Quality as Well are there any big Noticeable Difference between Over all PQ and 3D Quality ...as i already told 3d Glasses in 7500 are Superior than 7100
and lastly and Advise should i save 250$ or buy 7500 ...i will Ask the Same Question from 7500 Owners as well.....
post #217 of 368
The 7500 supports the evolution kit which is worth it if you plan to keep the TV for a while
post #218 of 368
i dont thinks i ll be getting the Evo kit just to upgrade the Dual core thingy to Quad core ill be more Interested to Enhanced the PQ rather than processor ...and i have Heard Evo kit Will be of 500$
post #219 of 368
pq will prob be similiar between the two sets
post #220 of 368
to me what matter most is PQ and 3d if these things are Similar than i guess i better Save 250 bucks
post #221 of 368
Got my new 46ES7500 delivered from Amazon this past Saturday. Deals on this set are not good right now but I had a time sensitive need.
I am happy so far, but a warning to anyone buying this TV. The settings out of the box are horrific. Frankly the worst I have ever seen. Luckily it only took a few adjustments and it looked good, if not great. I am getting it calibrated by D-Nice soon and am looking forward to the full potential.
post #222 of 368
Awesome....post the settings when he's done.
post #223 of 368
Originally Posted by jb24 View Post
Picking up a 60es7500 this week. Question for anyone who has mounted theirs -- what is the slimmest option? It looks like the Samsung ultra slim (picture hanging-type) mounts from last year are not designed for this year's models? Any opinions on the new 250 mount? Looks like it moves the TV out further from the wall than the 2011 options.
Any experience/insight appreciated.
Hi I'm new to this thread, you probably have already set this up, but for others with the same enquiry. I use this
http://www.youtube.com/watch?v=CtHSGfVzuvc
I am very happy with it ALTHOUGH...
I swivel the tv a fair bit, doing so places a fair bit of strain on the HDMI cables and TV connections, and they break. I am yet to find a product that will allow me to reverse the cable direction, in a very small space, so I can gaffer the cables to the back of the TV and take the strain off the connections. Ideally I need a short, very flexible Male to female HDMI cable, or 180 degree adapter that can fold back on itself (the ones on the market swivel to 90 or 270 not flat 180)
post #224 of 368
I picked up the 55' version on Saturday, I previously had an LG 7600 which I returned because of the backlight bleed.
I guess the better picture makes up for the cons but I would trade all the poorly implemented smart options fo a decently designed DNLA media service.
Try Plex on your Mac, iOS device and Plex Tv app. It works ok for me.
Also I find DLNA to be underwhelming. Buying an Apple TV and using the Airplay feature is the way to go.
post #225 of 368
I've been running Plex, Plex is awesome!
I've found using the mobile app, iPad version costs about 5 bucks, and airplaying to apple TV gives the best possible quality... the smart hub app is a bit buggy and doesn't seem to have the same picture.
post #226 of 368
just updated to 001046 firmware....
what does it actually do or fix?
post #227 of 368
we need a description of what the firmware actually does...
I dont know if this feature was always there or not...but i just noticed today after the 001046 update....
I can now actually set a time to turn on the tv at anytime I wish...and also turn off at anytime...I get 3 different times for power on and power off...
I'm not talking bout a regular sleep timer...
is this new? or it was always there...but I like it nevertheless....
post #228 of 368
The blinking hub is fixed it looks like
post #229 of 368
the flashing smart hub was actually fixed last week with another smart hub update... the firmware update for the tv 001046 has nothing to do with smarthub....they are two separate updates independent of each other....
post #230 of 368
Found this on the samsung official website after digging thru layers of onions....lol...
http://www.samsung.com/us/support/owners/product/UN46ES7500FXZA
Firmware 001046 not listed on the website yet....
post #231 of 368
post #232 of 368
contacted samsung again bout FW001046 release notes...here's the transcript...they promised me the release notes on FW 001046 in 2 business days.... eek.gif
Please wait for a Samsung Agent to respond.
You are now chatting with 'Silver'. There will be a brief survey at the end of our chat to share feedback on my performance today.
Your Issue ID for this chat is LTK56402500259X
Silver: Hi, thanks for reaching out to Samsung tech support. How can I help you today?
Visitor: I have the un46es8000
Visitor: just updated the firmware to 001046
Visitor: what does this firmware actually do?
Silver: I'll be glad to help you with the information.
Visitor: I hope so...
Silver: Could you please provide me with the serial number of the TV?
Silver: You can find the serial number on the rear panel of the TV.
Visitor: I'm not at home now...the model number is un46es8000
Visitor: I do not have the serial number
Silver: No problem. I'll help you with the information.
Visitor: thanx
Silver: Firmware's are released to fix the comparability issues with the apps and other issues on the TV.
Visitor: such as?
Silver: Firmware is a software program resided on the TV.
Visitor: I know that
Silver: If there is an issue with certain app with poor picture quality, the firmware update can fix the issue.
Visitor: Im a software engineer
Visitor: I know how it works
Silver: If there is an other issues like video quality and sound issues then they are corrected by the firmware update.
Visitor: I need the release notes on this latest one
Silver: Sure, I'll provide you with the information.
Silver: Follow the link below for your model TV:
Silver: http://www.samsung.com/us/support/owners/product/UN46ES8000FXZA
Silver: Click on the link to open the page.
Silver: Please go to Manuals & Downloads and select firmware.
Visitor: been there, done that...it does not state the release notes for 001046...
Visitor: only for the lastone 001041
Visitor: thats why Im contacting you in the 1st place
Silver: Click on the title " Upgrade File (Firmware) (ver.1041.1) " in the firmware title to see the notes of the latest firmware.
Visitor: 001041 is not the lastest....
Visitor: 001046 is...
Silver: I apologize for the inconvenience.
Silver: I see that the our Samsung web site has not been update with latest firmware version information.
Silver: Thanks for the information you have provided.
Visitor: yes...it need to be updates ASAP
Silver: I'll forward the details to the appropriate department so that they will work on this.
Silver: I appreciate for the information you have provided to us.
Visitor: SO YOU CANT GIVE ME ANY INFO ON 001046 HUH?
Silver: Sure, you will see the information on the Website.
Visitor: when
Silver: I'm sorry: we don't have information regarding the latest firmware update. I'll make a note on this, you can see the notes for the latest firmware with in 2 business days.
Silver: Can I be of any further assistance?
Visitor: I will hold you to that...I will be back in 2 business days...
Visitor: thanx...
Visitor: bye
Silver: You're welcome. Is there anything else I can assist you with?
Visitor: no thnax bye
post #233 of 368
Visitor: thanx
Visitor: such as?
Visitor: when
Visitor: thanx...
Visitor: bye
You came off as a jerk...
post #234 of 368
oh please, give me a break.... by your logic then, the rep treated me like a complete idot too then...even after I told him I knew how a firmware update works, he kept going at it...
post #235 of 368
post #236 of 368
Hello everyone,
I dont know alot about this tv hope you guys would be so kind to help me out, i bought a 55es7100 from best buy, it was an open box so total was a little over $1600. Doesnt seem to have any problems. It came with the 1023 firmware,now my question to you guys is should I update and what's the latest update?
post #237 of 368
Sorry guys for the above post, I selected wrong forum. Pkease disregard
post #238 of 368
Have any of the firmware updates updated the codecs from what is listed in the manual? My entire library plays on my PS3 and XBOX, but not the TV. If not, what do most of you use for HD codecs while using the built-in DLNA player?
-Eric
post #239 of 368
Plex over airplay is the best option I've found. XBOX won't play every codec, especially 3D... the smart hub app is pretty good as well.
post #240 of 368
Good Evening,
I just picked up a 60" ES7500 for my wife, but I have a bit of an issue and was hoping I might be able to solicit some advice. I am running Telus's Optik service, which is high speed through their router in my home. The wireless signal where the TV is located is weak. The wireless keeps dropping out. As a result of the weak wireless signal I went and purchased a Dual Band D-Link Wireless AC1200 USB Adapter and was going to plug it into my Samsung and hopefully pull in a strong signal or at least that was how it was explained to me at a big box store. My fear is if I do this I might some how damage the Samsung, I don't even know if what I am trying to do will work or makes sense. Routers have always mystified me... Anyway, where the TV is now is where it has to go, due to the configuration of my living room. Any information or assistance regarding the strengthening of my wireless signal either from my router end or TV end, would be greatly appreciated. One side note, I do have a Netgear 3000 (I believe it's called) that plugs into a wall socket closer to the TV, but the signal keeps dropping out there as well.
Thanks very much in advance, Andrew
