I'm getting a new RS45 projector for the theater room to go along with a Kuro 600M currently set up. I'm debating on getting a Lumagen RadianceXE and using SpectraCal's Rent a Kit was hoping to use the AutoCal feature and the Lumagen to get the most out of the two displays.
Can anyone comment on if this will be worth the effort? I know the Lumagen can help enhance both displays, but I would really only consider getting it if the AutoCal feature does almost as good as a professional. If not then I'll skip the Lumagen altogether and possibly put that money towards having a pro try to calibrate both displays.
Appreciate any info/feedback.
