I am building the audio for my home theater and I have some questions about if what i am thinking about getting is good. Please note that I will be getting a 3d projector...so that is important. Also sorry about the links, but they would not allow me to post many. Just add a .com behind amazon and it should work. These are the products that I chose:
Subwoofer:
Sony SA-W3000 amazon/Sony-SA-W3000-Subwoofer-Each-Black/dp/B000OL22T2
Front Left and Right:
Sony SSF-7000 amazon/Sony-SSF-7000-Floor-Standing-Speaker-Woofer/dp/B000OG4E2U/ref=cm_cr_pr_product_top
Center:
Sony SS-CN5000 amazon/Sony-SS-CN5000-Center-Channel-Speaker/dp/B000OGA81Q
Surround Sound:
Sony SS-B3000 amazon/Sony-SS-B3000-Bookshelf-Speakers-Black/dp/B000OG6I6A/ref=cm_srch_res_rtr_1
A/V System:
Denon AVR2312Cl amazon/Denon-AVR2312CI-Integrated-Surround-Receiver/dp/B004Z0S7JW/ref=cm_cr_pr_product_top
For this system I am still deciding on whether or not I should get 2 subs. I will also be getting 2 pairs (4 speakers total) of the SS-B3000. Will this system produce loud, and good sound? Also should I get an amplifier for the speakers or is the 100w per channel on the A/V system good enough to power these speakers to high levels. If I should get a amp then what would be the best amp to use with this system. Also I would like to stay with the Sonys, because even though they are not as good as they used to be Sonys products are very good and the speakers are some of the best I have ever owned. So to sum up all of my questions here they are:
Is this a good setup?
Will the A/V be able to power these well when I turn the volume up high?
Should I get 2 subwoofers?
Do I need to get and amp or is the 100w per channel on the A/V system adequete?
If I need an amp, which one should I get?
Will this system produce good, surround sound?
Subwoofer:
Center:
Surround Sound:
A/V System:
