I had a question regarding throw and lens size....this is a bit theoretical and NOT a practical issue I'm dealing with. I don't have an A-lens yet but I'm planing to for my upcoming build.
I know I need to fit the beam inside the lens. Assuming a long throw ratio of say 2.2+....My question is can we get the beam too small? In other words if we are using only the middle on the lens will it modify the horizontal stretch enough to make a difference?
Thanks for your thoughts
