I'm attempting to bend some 1/4" MDF in my current build.
I tried a dry run yesterday to bend two 1/4" panels around the braces using some clamping jigs i made. I had planned on wetting the panels before the process but wanted to see how much resistance the dry boards put up... Bad idea. Didn't seem like they were putting up too much resistance, but when i took a closer look i noticed they split before i torqued the clamps all the way down.
I imagine things will go better if i wet the boards. But that raises another question. What is the effect of wetting the boards on the glue that i use to laminate them together and to glue them to the rest of the cabinet? Glue cleans up nice with a wet rag. Will a wet panel screw up my glue's ability to set? I think white and yellow glues dry by evaporation? In that case i imagine things would be fine when the boards eventually dried? Anyone?
In any case, i'm going to try to find some 1/8" MDF but don't expect success. I think masonite is easier to find. It comes thin and bends easy. I did some searches but only found one thread talking about using it in speaker builds - and the poster was going to glue it to hardwood, which raises it's own set of problems.
Has anyone used masonite directly for the walls of a curved cabinet? I would be veneering over it.
Joe
Joe
And the wear on tools is
But it cuts clean and routes smooth, so i think i'll probably continue to work with it.
