Hello all!
I own the 50U50 and have been considering getting the CYS 2100 SCART RGB to YUV adapter for my oldskool consoles (Genesis, SNES, Neo Geo) but I've heard that some TVs can actually accept RGB via component with no conversion.
My questions are:
- Will this TV accept an RGB signal (like from a PS2 switched to RGB in the settings)?
- Will this TV display a 240p resolution over component?
My computer is currently hooked up to the TV via component, as I sometimes use the TV as a 2nd monitor. Would setting the desktop resolution to 320x240 be an acceptable test (assuming Nvidia will let me set a custom resolution that low)?
If anybody wants to answer a couple bonus questions:
If I wanted to build an RGB cable for my Neo Geo (assuming RGB works on my TV) where would the composite sync signal go? (My wild guess is the green plug)
and
What color mode should I set my 360 on? (totally unrelated!)
Edited by Billkwando - 5/14/13 at 12:41pm
