Originally Posted by derek533
Guys, need to know how much your set buzzes. Mine is audible from about 8' away during bright scenes. It's not loud and with the volume up, it drowns it out. However, when playing a game, during the loading scenes when all is quiet, there is definitely a discernible buzz that is clearly detectable. I bought it from Amazon a couple of weeks ago and it was delivered this last Tuesday. I should know the answer to this, but will it improve as the panel ages at all? Should I exchange it? I have an older 42PX75U but since it's a 42" set, I don't think it's fair to necessarily compare the buzzing between the two sets as I'm sure the 60" requires more wattage to drive. I guess the question is, how much buzzing should I really expect during quiet, bright scenes?
BTW, my settings are set for break-in i.e. low contrast and brightness.
Thoughts?
Thoughts?
I would try to determine if the source of the buzz is internal or external.
Did you use the ferrite rings on your HDMI cables? If you disconnect all inputs does it still buzz?
Are your HDMI cables running parallel and close to the power cables?
Are your wall sockets properly phased (wired) and grounded?
Are there Wall warts and other AC to DC converting equipment on the same circuit or nearby?
You might want to consider what electrical appliances are on the same circuit as your U50. This is a well documented problem with high end audio equipment...refrigerators being the most common offender. Also dimmer light switches are notorious as well as florescent lights for being sources of hum/buzz. Most audiophiles are quiet familiar with the problems that just the electrical lines them selves can add (what is upstream from you) .
Are there Wall warts and other AC to DC converting equipment on the same circuit or nearby ?,IE Heating pads, electric blankets, aquarium heaters and doorbell transformers.
I have a U50 as well. I ran a dedicated electrical circuit just for the refrigerator so as not to add the clicks it creates every time the motor cycles on and off. . Dead silence on the TV. A Blue ray DVD is stunning.
here are some trouble shooting steps that might help.
http://www.ntopix.com/files/Killing_Buzz.php
If you do determine the buzz is from the U50 ...check to see what your contrast setting is..lower it if it is high..this may reduce it enough that you do not notice it.
Edited by Ernie in NH - 12/2/12 at 10:03am
Here's hoping 8 hours of golf channel plus 4 hrs of Crackel or Blu Ray movies (all full screen) for 10 days straight was an O.K. break in technique. What happened to the days when you just buy the sucker, take it home, plug it in and look at it. I don't want to fly the Space Shuttle I just want to watch TV!
. custom mode is ok, but the best mode for this tv is the cinema mode. download the AVSHD calibration disc from this forum and run those, that will get you a much more accurate image (find on cinema it's more like this)
