Originally Posted by
TrevorS
My 50U50 arrived yesterday afternoon and I spent the evening watching TV and eyeballing the picture into my traditional preferred zone. The room has a fairly heavily curtained window and sliding glass door on the South-West side with the TV at the North-West end and a ceiling centered dimming incandescent fixture. There's a walkway into the kitchen at the South-East end with a counter pass-through nearby (kitchen has a ceiling fluorescent fixture). A little light enters via the windows and easily more indirectly from the kitchen fluorescent. Following install I sat down and was a little concerned about some obvious reflections off the screen, but happily, with the set displaying a signal, I see no hint of reflection -- looks perfect, even with the overhead incandescent maxed (I usually have it either off or perhaps half on).
As long as I can avoid image retention issues, I think I should be fine -- very nice picture! I'll eventually do a Video Essentials calibration, but in no rush given the set needs time to settle in. No sign of a buzz last night with my head behind the panel and normal program material -- course, it probably helps that my contrast setting is so modest.
Should have revised this awhile ago but have been distracted
! I decided I like C.A.T.S. ON for TV viewing since it adjusts for room light, however, it also requires Color Management ON and different Contrast, Brightness, and Color settings to match darkened room non-C.A.T.S. viewing. I went Standard mode with C.A.T.S. for cable TV, and Cinema for disc playback.
For TV (coax cable):
Mode -- Standard
Contrast -- 80
Brightness -- 65
Color -- 31
Tint -- +1
Sharpness -- 50 (factory default, not fooled with)
Color Temp -- Cool1 (best gray scale)
Color Mgt -- ON
C.A.T.S. -- ON
Video NR -- OFF
Aspect: Screen Format -- (current selection)
Aspect: H/HD -- Size1 (reflects current signal)
HDMI -- N/A
3DY/C -- ON
NR (both) -- OFF
Black Level -- N/A
3:2 Pull Down -- AUTO
For Disc (HDMI & Component):
Mode -- Cinema
Contrast -- 48
Brightness -- 50
Color -- 50
Tint -- +1
Color Mgt -- OFF
C.A.T.S. -- OFF
Video NR -- OFF
HDMI: RGB Range -- set to match player (NONSTANDARD if player set for Extended or Cinema Black)
HDMI: Content Type -- OFF
3DY/C -- N/A
NR (both) -- OFF
Black Level -- LIGHT
My viewing is a mix if 4:3 and other ARs, so my settings for minimizing image retention are.
Pixel Orbiter -- ENABLED
Side Bar Color -- DARK (can only be set with 4:3 format selected, I find LIGHT too distracting)
Scrolling Bar -- I regularly activate this after a few hours of fixed bars/images on the screen.
FWIW: I generally prefer to preserve the original aspect ratio. The only screen formats that accomplish this are HD and non-anamorphic source 4:3 and ZOOM, or else FULL -- both JUSTIFY and H-FILL distort the image. 4:3 format with an HD source cuts off the sides.
I continue to be very pleased with the picture
! First time I've ever had a TV that is so interactive though (thinking IR avoidance), guess that's part of the cost of plasma -- LCD is basically set and forget.
PS. The only line bleed I'm seeing so far is mild dark shading to the left and right of black text on green title frames. Have yet to hear any buzzes from either front or back of the TV.
PPS. I like that the TV remote controls my Panasonic BD player via HDMI. The TV also senses player activation and automatically switches to it, and if I turn off the TV, it in turn shuts down the player -- pretty neat design. (I have three players switched into the one HDMI input and so obviously, this only works if the Panasonic is connected.)
Edited by TrevorS - 12/25/12 at 2:47pm
