Originally Posted by cheu
Just bought the 60 inch U50 on amazon last week with the 10% off email. The only problem I have is with the hdmi connection to my desktop pc. Every time I restart or power up my desktop pc with hdmi cable plugged into my pc and the tv, I get the "No signal detected" error message on the tv. So I called Panasonic hotline and the only solution they gave me was to unplug the hdmi cable before I boot up or restart the pc and wait until windows loads up, then plug hdmi cable back to pc or tv. The rep said it didn't matter whether I disconnected the tv or pcI hdmi cable.
I have all of my connections (directtv, ps3, desktop pc) plug into my reciever. I have also tried to plug my pc straight into the tv's hdmi port and have the same issue.
I have the resolution set to 1920x1080 and 60 hertz on the pc. I have tried 24, 29 and 30 hertz.
Does anyone else have this issue or a workaround? It's very inconvenient to have to unplug the hdmi cable each time my pc boots up. My 2006 Pioneer 50 inch plasma never gave me this issue. Although, I realize the I am comparing a $3000 tv to a $750 tv when bought new, I figured these things were standard features on all new tvs.
What type of video card do you have? Are your drivers up to date? I do not have this issue with the TV on my system using a Radeon 6950 and the latest drivers. In fact, my card auto detects my TV in the bios and outputs to it correctly (and my monitor simultaneously) even though I have double output disabled in windows (it disables after I get to windows and it loads those settings automatically). Do you get any output in the bios if your TV is on and you have your TV's input set to your computers hdmi?
Make sure you have it set up correctly to output. If you are using dual monitors, make sure you use the command WindowsButton+P to set the correct output method in windows. Depending on how new your card is, it should be auto detecting a signal and outputting in the bios screen. Even if you only have one monitor, you can use WindowsButton+P to cycle through the outputs blindly until you get a picture (you have to press P twice while holding the windows button).
(still not has bad as the Yamaha Rx-Axxxx thread lol)
