I'm having some problems with getting a connection with my AV receiver. I'm using a Denon 3312. I'm not sure if it's the TV or the receiver yet, but I'm fairly certain it's the TV. Basically I have to move the HDMI cable back and forth between the 2 ports until it picks up the signal and brings up the Denon menu. Then I can navigate the Denon menu as long as I want it seems, but as soon as I connect a cable to the Denon to try and get a source set up, the screen blacks out and it says no signal. Then the HDMI in on the TV just seems to stop working period for a bit. Even if I run a cable direct from a PS3 to the TV. Anyone at least have some advice on how I can troubleshoot this?
I thought it might be faulty HDMI cables a while back when the connection kept turning off and on in the middle of games or movies, and I had to play with the connections a bit to get it working again. It seems that the signal shutting off would happen whenever someone walked close by the set and the floor vibrated. I ordered a few cables with redmere from Monoprice thinking that might solve it, and I can't even get these ones to establish a connection with the PS3 and TV. Any help whatsoever would be greatly appreciated. I have no idea what I'm doing.
