Originally Posted by
lfeickert
If you have the pixel orbiter on to help reduce image retention, the borders will also change in size/width; also perfectly normal.
Odd black borders? If you're on Full/Size 2, pixel orbiter is certainly the reason and I suggest turning it off for best picture.
I've played 10 hours of Battlefield Bad Company 2 on this TV so far (in about 2-3 hour periods over the week), static white images on screen included the ammo counter, my crosshairs, the minimap and the scoreboard; so far no image burn in or even retention. Upon a pure white or pure black screen, everything looks as it should, and with no pixel orbiter. Your mileage may vary, but I'm confident enough to turn it off.
Even if you were to somehow experience any burn in, pixel orbiter would make it very slightly better as it just shifts 2-3 pixels per operation. You'd just end up with a blurry burned in image, just like you end up watching a blurry TV with it on.
Menu > Setup > Anti Image Retention > Pixel Orbiter > Disable.
