AVS › AVS Forum › Display Devices › Display Calibration › Best meter under $250.00
post #1 of 4
I have a Benq W6000 DLP projector and was looking for the the best meter under $250.00, the more info the better. Thanks
post #2 of 4
Well if you're looking for a meter and home theater calibration software, then you're probably looking at something like the C1 (spyder 4 enhanced) with CalMAN. The next step up that blows your budget by $50 is the i1 Display Pro (3).
There honestly isn't much selection for new meters with the software you'll need to calibrate a projector under $250.
SpectraCal does have a rental program as well.
post #3 of 4
What would be the easiest auto cal set up for a beginner? for a projector set up
post #4 of 4
The i1 Display Pro is going for 250 on newegg. This coupled with HCFR would be a good place to start imo.
