Contacted the manufacturers and I might as well have been talking to a brick wall as little help they were.
I am looking into purchasing one ore more of the below listed TV's and would like to know if anyone here knows if these TV's have overscan and/or if it can be shut-off so I can see the all the signal the TV channel or dvd or blu-ray has to offer (by that I mean on 1.33 content I will be able see the top and bottom fully and not cut off like on the old square crt, 1.85 on all sides no lost image, and 2.35 the left and right images)
Element Electronics ELDFC551J
LG 47CS570
Sanyo DP55441
Toshiba 65HT2U
OR any models you know that fit my needs - Thank you in advance.
If you are wondering why I went with LCD's only and no internet model enabled TV's it is because I dislike how Ege Lit LED's in the above price and size range have bad lighting in the interior of the picture & I DESPISE INTERNET ENABLED TV's. If I want to be on the internet I will be on a computer and not a TV.
LG 47CS570
Sanyo DP55441
Toshiba 65HT2U
One would suggest not setting up the tv to connect to your or anyone else's wireless network.
