Originally Posted by
AV Science Sales 5
The EN4K is not available DIY. It is a very good screen to place speakers behind. I have owned Center Stage and EN4K. Love the image that EN4k provides. With EN4K you can't go as large as you can with a higher gain screen, but the image sure is good on EN4K. If you have any specific questions, shoot us an email.
Yes, I am definitely considering between the en4k and the center stage now.. I'll just have to decide on which projector and my size..
Say, if the size I am looking for is about 130-140 inch diagonal / 16:9 ratio, and using the Panasonic PT-AE7000, would you recommend the en4k?
The review of this projector is here:
http://www.projectorcentral.com/pana...tor_review.htm
I am also considering the Epson 5010, which is brighter, but perhaps with less features and slightly less contrast.
Also, this may sound like a silly question. If i were to play 2.4 ratio movies, would i need an anamorphic lens or is it all about adjusting the projector's focus?? I am a bit confused here. A projector salesman told me that without an anamorphic lens, no projectors in the world can play 2.4 materials. But that to me is absurd. If my tv can play 2.4 materials, why not a projector?? Why do you need an extra lens?? Can't it be as simple as zooming in or out to fit whatever image you want on your screen??
