AVS › AVS Forum › Audio › Audio theory, Setup and Chat › When doing an Auddessy config on a Denon
post #1 of 5
Does it matter if I run thru the setup with the mic and THEN change the speakers to small? Or must I set them to small first before doing the microphone test thing?
Sorry if dumb question
thanks
post #2 of 5
This thread will answer EVERYTHING:
http://www.avsforum.com/avs-vb/showthread.php?t=795421
Bill C
post #3 of 5
Run the auto-cal then check what the receiver has set the speakers to, if large change to small and set cross over to what ever you need it to be, usually 80hz.
changing the large/small settings, crossover settings, speaker trim levels does not effect the auto cal equalization.
post #4 of 5
one clarifying note...
xover settings, as long as you do not lower them, do not effect the calibration...
post #5 of 5
thanks all!
