AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official LG 47LM8600/55LM8600 Owners Thread
Official LG 47LM8600/55LM8600 Owners Thread - Page 37
post #1081 of 1377
Originally Posted by ceeece View Post
... I notice random "frame skipping". Basically it looks like an entire frame of film is skipped. So a smooth camera pan will be interrupted slightly or a person walking by will move forward slightly as if "bumped". I don't know if this is jitter or not. LG CS told me to turn off TruMotion but this didn't help ...
Have you tried double-checking that TruMotion is OFF for the particular input you're watching? I think it's set on a per-input basis, and it seems to want to turn itself back on sometimes, for example if you used the Picture Wizard recently?
post #1082 of 1377
TruMotion is definitely turned off. I made sure to check the input settings often. I haven't used the Picture Wizard at all. I used calibration settings I found online.
post #1083 of 1377
post #1084 of 1377
Hi All,
I have a general question. I'm confused with handling outputs for external speakers. If I want to use the tv's apps (such as netfix), is there anyway, (outside of the toslink) to hook up external speakers on the 8600?
Clearly if I have a bluray player, I can make this happen, but Let's say i want to either use Netflix on the TV, or stream some video the tv, is the only option the tos for external audio?
post #1085 of 1377
By chance is there a protective film over the LM8600 screen at first? I can't tell, but in the top right corners I see a +, and it appears there is some film that can be pealed off. (I dont' want to start trying to pull at it if it's not there smile.gif
post #1086 of 1377
Originally Posted by spman2 View Post
Hi All,
You have two options I believe.
1. Use Toslink back to the receiver or soundbar.
2. Have a receiver that supports ARC and have the TV send audio back to the receiver via HDMI 1.4. (This is how I handle it).
post #1087 of 1377
Guys,
I found out that via my LG bluray player, I get some sync issues when playing 3d Blurays. This is then connected with HDMI 1.4 ARC to the lm860v. Anyone else experiencing these?
post #1088 of 1377
Originally Posted by mohawk0618 View Post
Guys,
Where is the sound coming out of. The receiver, or the TV. Further, please tell me where all the cables are just to verify:
It sounds like you're doing this:
Blu-Ray ---(HDMI/ARC)---> TV (with return channel to receiver)
And that's it. One cable so far, right?
post #1089 of 1377
Hi TGM1024,
Yeah exactly like you described:
the sound is comming from the receiver and I get a sync issue when watching 3d blurays. When I select "TV speakers" , there is no problem at all.
I have to set the bluray system to 300ms in order to correct the sync, but when switching back, I have to change it again.
post #1090 of 1377
Hi TGM1024,
(Fixed post order) Don't top-post----it screws with the nested quoting.
3D only? What of 2D blu-ray?
post #1091 of 1377
Only 3d bluray there are sync problems, 2d is just fine.
post #1092 of 1377
Maybe search through the 7600 thread? Tampa8 frequents there, and he's very knowledgeable about THAT model, which might show this kind of thing. There's something about this that seems simple to me that I can't quite put my finger on.
post #1093 of 1377
New Firmware update 04.34.02!
post #1094 of 1377
Any changes on the firmware, I checked yesterday, did not get any update or something.
post #1095 of 1377
Yea, they added a bunch of stuff to the "smart tv" and I noticed a new settings option, True Cinema"
post #1096 of 1377
where do i find the true cinema option? i do not see it
Edited by pty08 - 3/20/13 at 6:47pm
post #1097 of 1377
Picture options in Expert
post #1098 of 1377
Well that just sucks!!!! Went to go pick up my TV from the freight shipper in town and this is what I see... eek.gifmad.gifconfused.gif
IMG_0565[1].JPG 304k .JPG file
IMG_0566[1].JPG 291k .JPG file
IMG_0567[1].JPG 249k .JPG file
IMG_0568[1].JPG 281k .JPG file
IMG_0569[1].JPG 284k .JPG file
Refused delivery and now I have to act a fool with Amazon tomorrow!
post #1099 of 1377
Oh freaking good grief.
Contact Amazon via an online chat or phone call and tell them how this greatly inconvenienced you. They usually are kind to customers.....perhaps they'll offer something expedited for free.
post #1100 of 1377
Contacted them and all they are willing to do is refund. It was a fulfilled by Amazon order but they won't send another. I was hoping for a replacement via an overnight shipper. Nope denied. Not the Amazon I use to know.
post #1101 of 1377
Well hooray to the half ass koreans the latest firmware turns off the logo light if you turn it off in a certain sequence,on my tv(s) anyway ,still no standby option in the menu like it came with out of the box ,it kills me that these updates are so sloppy,I'm glad the LG displays we use on elevators use our own firmware I couldn't deal with half ass sloppy firmware on a daily basis....I know LG monitors this board ...message to the board monitor "fix your half ass firmware and restore the standby light option it can't be that hard you had the option in previous firmware go look at your notes".
post #1102 of 1377
ARRRRRRRRRRRRRRRRRRRRRRRRRRRRRGH. Avsforum needs to have a punctuation quiz before joining. LOL.
post #1103 of 1377
We're not in your writing class here ,sad you gotta look for problems to find self - esteem...if you don't like how I write then skip it.
post #1104 of 1377
Good idea.
post #1105 of 1377
LG.............. FIX THE LOGO PROBLEM SO IT DOESN'T HAVE TO BE TURNED OFF EVERY TIME THE TV IS POWERED BACK ON....YOUR FIRMWARE IS GARBAGE.
post #1106 of 1377
Let me know how it goes right away please!
BTW, the cost is now higher. Do they honor the original price?
Further
I wouldn't risk the 2012 line anyway. There are reviews out for the Sony 550 line already. Possibly the 802 as well.
post #1107 of 1377
FWIW, (perhaps a lot)
The [non-local dimming] Sony KDL-xxR550A has finally been reviewed.
  • It is low end, a 120Hz (with the sony version of pulsing to 240Hz) edge-lit.
  • Note: the LM7600 / LM8600 are purportedly NOT true 240Hz either. HOWEVER, search various threads in AVS for the pitfalls of non-pulsed sample and hold. FAR too much to do here.
  • 50" / 60" / 70"
  • It has a non-reflective coating.
  • [at least with the reviewers TV] It had inky black top and bottom during 16:9 movie showing.
  • (and it is passive 3D).
  • IF YOU ARE IRRITATED by the problems with LG high-end sets, Keep track of my R550A and W802A threads
  • http://reviews.lcdtvbuyingguide.com/sony-lcd-tv/sony-kdl70r550a.html
R550A is far from perfect with its own problems. But might be less aggravating already. And no, I am not someone to put faith in the TVs that reviewers get from manufacturers, NOR do I put naively put faith in any one reviewer.
That said, I'm waiting desperately for the first W802A, potentially the true contenders to the 8600.
Edited by tgm1024 - 3/22/13 at 11:36am
post #1108 of 1377
Sorry if this has been covered but i just recently used the pandora app on my 55 lm8600 through my avr (optical cable/ doesnt support hdmi) and it was horrible! i play everything from movies on my external to regular tv through my digital hookup without a problem and i went to use pandora and the quality was terrible. The speakers were distorted on a low volume whenever some type of bass was being played. Has anyone else encountered this? I tested my avr by playing music off my external through my tv, through the digital input and it did not contain any distortion. I also used other inputs from different devices with the same outcome. So i know my avr is not the problem. Thanks.
post #1109 of 1377
Talked to the LG engineering dept they're promising a firmware patch to fix
the logo light problem and to restore the power/standby light option, they told
me the importance of this has been escalated , hopefully this will not be a
slow moving process...... from what I understand this should be available in
a couple weeks.
post #1110 of 1377
a couple weeks.
Hope this will include tv's in Australia as the last three updates have not fixed logo light problem.
