Originally Posted by aaronwalker1974
The only way to reduce the effect of the light bleeding at the top would be to reduce the backlight and try the local dimming at a higher lever (ie. med / or high). It will help but maybe not eliminate it completely. As far as the washed out color, maybe try some of the settings listed above? The colors on my 7600 have good pop although the blacks do get crushed a bit.
I applied the settings that HyperC posted, and things are looking much better. My contrast, backlight, and brightness settings were nowhere near his, and the colors are better. I'm going to wait until tonight to see if the lights at the top come back, but that could have been caused by my settings or something.
A couple of quick questions:
- is there a remote command for jumping directly to a Picture setting? I want to setup my activity-based remote to switch it to Game when I use the PS3/360. I know you can set a Picture setting per input, but everything uses one input on the TV right now.
- is there a manual way to apply a Picture setting to specific inputs? The calibration wizards lets you do it at the end, but I haven't found a manual way yet.
![Disney WOW: World of Wonder [Blu-ray]](http://cdn.avsforum.com/d/da/50x50px-ZC-dadc69a0_B0045ASBLG-51TziBcqZFL.jpeg)
