AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Looking for deep (20" plus) AV cabinet for receiver
post #1 of 3
I didn't think this was going to be as hard as it is but I really am having the toughest time finding a cabinet to accommodate my Yamaha receiver which measures 18 3/8" deep. You would think there would be more options out there. Ideally I'd like to have 20" on the shelves to leave room for wires. Most cabinets are less than 18" inside depth. What are you guys doing?
post #2 of 3
one place you might try is "www.racksandstands.com"
post #3 of 3
Salamander Designs Synergy system with extended back panel - something like 23-24" deep.
